Small Form Factor laptop dvd drive help
Discussion in 'Hardware' started by pmk, 15 Feb 2004.
  1. pmk
    pmk What's a Dremel?
    28 Jan 2004
    lo all,
    just got my hands on a new IBM laptop DVD drive P/N : 92P5990
    i want to use it in my current project box but there is a small problem, the connector at the back doesnt seem to be a standard drive connector it looks like this
    and my converter looks like this
    my old Dell laptop 24x cdrom was in a shell and once dismantled it had the proper conector, but this one doesnt seem tobe the case (dont want to risk ripping it apart yet)
    any ideas? or anyone can shine a light on this type of connector?
    cheers
  2. TOPLOADER
    TOPLOADER What's a Dremel?
    14 Jan 2002
  3. pmk
    28 Jan 2004
    correct me if im wrong but i allready own that converter? the converter that i have is this one
    http://www.kustompcs.co.uk/product.php?view=5417
    that fits my old laptop teac cdr fine but the ibm drive is diffrent
    please reply if the picture is the same but the product is diffrent if its what i need cheers :)
  4. TOPLOADER
    14 Jan 2002
    if you got it from kustompcs then its the same one as i have as i put them onto the supplier
    they are the only converters i have seen sorry
  5. MadD_b0mBeR
    MadD_b0mBeR What's a Dremel?
    25 Oct 2003
    sorry m8, its a loverly DVD drive, but i have never seen one of those conncetors before in my life.
