Cooling Laptop getting hot
Discussion in 'Hardware' started by Ploo, 4 Jun 2010.
  1. Ploo
    Ploo What's a Dremel?
    1 Oct 2009
    I'm currently using a Vostro 1500 which I will have to be sticking by for another few months. Although it does run very hot easily reaching 90 degrees on both cores.
    I figured part of the reason is the dust that's accumulated in the 2 and a bit years of usage, especially that it is turned on a lot, lets say an average of 12h a day over that time.
    I was thinking of taking the back cover off and using a compressor on low pressure to blow the dust out. I heard that using a hoover would create static so I guess that's not an option.
    Any other ideas how I should go about this?
  2. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    take the back off. there should be a heatpipe from the cpu (and possibly gpu) to a heatsink near the fan. the fan blows air through the heatsink and out of the case.
    all you will need to do is take off this heatpipe (its attached to the heatsink) and blow the dust off that. you might also want to re-apply the thermal paste to the cpu.
  3. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    i've seen real tatami's of dust in laptops. so yes, maybe that is a good idea.
    i don't think it is really necessairy to remove the cooler from its position. usually, if the back is gone, you can remove the dust without any problem.
    also, if the back doesn't come off, sometimes there are screws under the keyboard that need to be removed.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Sometimes its easier just to take out the fan than remove the whole heatsink, as if you do this you'll have to reapply the thermal paste.
  5. murraynt
    murraynt Modder
    6 Jun 2009
    i always use a hoover on my pc.whoops:hehe:
  6. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    We use hoovers on (desktop) computers at work, when they're mucky. No worries.
    It shouldn't be too hard (hopefully) to access the fan and make sure it isn't clogged up with dust.
    Also, use the laptop on a hard surface e.g. a desk, rather than a bed or your lap, as the laptop sinks into soft surfaces and block the air intake.
  7. Akuman
    Akuman Waffles
    5 Jun 2010
    Raise your laptop.
    I've had so many overheating issues in the past and after I raised the back end of my laptop I've found my temperatures to drop quite a bit.
    If that still doesn't solve the issue then I suggest trying out a laptop cooler.
  8. murraynt
    murraynt Modder
    6 Jun 2009
    Phwee.Thanks
  9. adidan
    25 Mar 2009
    Aye a bit of a clean and raising it will help.
    My GFs ancient laptop used to overheat and shut down even just watching a video, just had it to bits, cleaned it out, removed the crappy thermal pad and put some arctic silver on and now the fan doesn't try to launch the laptop into the stratosphere. :)
  10. Sexton
    Sexton Minimodder
    2 Jun 2010
    One of those laptop cooler with loads of fans should do the trick.... believe Akasa do a good one.
  11. Gothic-Yoshi
    Gothic-Yoshi The Matrix has you!!!
    2 Jun 2010
    I have an akasa laptop cooler for my sony vaio the coolers are awesome and drop temps a lot.
  12. nathanddave
    nathanddave What's a Dremel?
    18 Apr 2010
    I have had quite a few laptops over the years, the main heating problem that I found with them is the fan not being able to get rid of the hot air because its so close to the surface of whatever it is on. This also doesn't help when you put it on a bed, as I have done many times before (and yes they got very hot indeed).
    Laptops are a lot tricker to try and clean from my experience, if you take the back cover off, some laptops you are able to see everything others not so much. But if you are able to get at the heatsink do remove all the dust, as they will be a lot most likely.
    In future try and raise it or someway to allow the fan to have a greater distance to blow the air, or get a laptop cooler, which I have never used before, but I am sure they will work
