laptop hard drive pin assignment
Discussion in 'Hardware' started by lessthanjake, 8 May 2004.
  1. lessthanjake
    lessthanjake What's a Dremel?
    24 Jan 2004
    does anybody know the pin assignment of a laptop drive as i salvaged a laptop drive from a rubbish box at work and was wondering if it has a chance of working before i buy an external enclosure the thing is 3 pins are missing the pins that are missing are in red
    if anybody can help it would be greatly appreciated
  2. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    I believe that the 40 (39) pins on the left are the standard IDE cable pins, and the 4 on the right are what you get from a standard molex cable for power; one 12v, one 5v, and two grounds. Since there's always one pin blocked out in an IDE cable (keyed so you don't get it the wrong way round) I'd say that all the pins are there and that the HDD is good to try out.
  3. lessthanjake
    24 Jan 2004
    thanks a lot i will try that out then
  4. Penrhos
    Penrhos What's a Dremel?
    23 Oct 2001
    NO -Thats not correct... the 4 pins are for master/slave/cs.
    if you count the pins there are 44 not 40 this is because the power is on the ribbon cable..
    EG I have a IBM DTCA-23240 2.5inch drive. check the datasheet
    http://www.hitachigst.com/tech/techlib.nsf/techdocs/85256AB8006A31E587256A9D0071BD64/$file/dtca_spw.pdf
    see pages 42-46 for pinouts.
    missing pin = 20 = key.
    41,42 = +5V, 43 = GND, 44 = reserved.
    The best way to use this is buy a 2.5 - 3.5 drive adapter kit or a usb2 2.5 inch caddy (£10 for either at show I went to today).
  5. Kameleon
    29 Apr 2003
    OK, thanks for sorting that out. I tried googling to check out my info but didn't find anything in particular, I'd think that what he wanted to know (does the HDD have the right number of pins to use) was still answered correctly by me, so no harm done ;)
  6. reflex_1
    reflex_1 What's a Dremel?
    24 Mar 2004
    the pins look ok but if you want to check before you buy a caddy just buy a 2.5" to 3.5" adapter and test it out of your pc if you don't have a lappy, they cost around £5 from an infamous auction site
  7. BjD
    BjD What's a Dremel?
    10 Apr 2003
  8. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    i found this helpfull when i was working on an adapter:
    and no it isnt mine, i have just re-hosted the picture, and i cant rember where it came from, so credit goes to the people in the copyright :p
