Notebooks Laptop HDD Adapter
Discussion in 'Tech Support' started by Interloper, 17 Sep 2010.
  1. Interloper
    Interloper Faux Pro Modder
    17 Jul 2009
    Hello!
    I was asked to repair a friend's laptop and I have been unsuccessful. So here I am, asking for some help.
    I have a laptop HDD and it refuses to boot anymore.
    The person has gone ahead and bought a new laptop so now I am at the stage where I want to extract their personal files so they can transfer them to their new laptop.
    I have searched for laptop HDD adapters and haven't been successful in finding one that seems to be compatible with the HDD interface type. It is a SATA drive, but from all the adapter pictures I've looked at, it wouldn't work.
    Here is the HDD
    If anyone knows of a relatively cheap adapter that would work, please share.
    I should also mention I am in the United States.
    Thank You!
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  4. thehippoz
    19 Dec 2008
  5. Gryphon
    Gryphon What's a Dremel?
    24 Apr 2009
    In that pic it looks like your HDD is still in the tray to attach it to the laptop... maybe if you take it out the tray you'll get the normal sata ports?
  6. Fingers66
    30 Apr 2010
    After re-reading this, I think the sticking point is the "non-standard" interface on the 2.5" hard drivef. Have you seen that before?
    OP: what brand/model laptop did it come from?
  7. Fingers66
    30 Apr 2010
    LOL, I had to turn my laptop screen on it's side to see it but I think this ^ may be right.
    bulldogjeff likes this.
  8. Interloper
    17 Jul 2009
    It came from a HP Pavillion dv6000? I believe that's it.
    I'll check on the cage option after work.
  9. bulldogjeff
    2 Mar 2010
    Oh yeah...lol thats what I've just doing:duh:. As has already been said, get it out of the caddy and then just hook it up to a normal PC as you would a normal HDD and then you can access it.
  10. Interloper
    17 Jul 2009
    Yup, I didn't fully examine the HDD. :duh:
    Tray removed, standard SATA connectors were found. :duh:
    Thanks!
    Good news out of this is that I may have just received a free laptop. Ill wipe the drive and put Win 7 on it after and see if it fixes it. :D
  11. Interloper
    17 Jul 2009
    OK, need some opinions/confirming what I think is wrong with this drive.
    I have hooked it up to one of my PCs as a secondary drive and I am able to navigate around in it. However, the minute I try to do a copy from that drive to mine, the whole PC freezes. I've tried many times and each time it yields the same result. Frozen PC, have to do a hard shut down.
    I am leaning towards the direction that the drive is damaged internally somewhat.
    I'm out of ideas on how to maybe save these files.
    The drive will NOT boot.
    The drive will freeze if I try to do ANY sort of activity within it, save for navigating.
    Any other approaches out there?
    Thanks in advance.
  12. Fingers66
    30 Apr 2010
    Try using a disk imaging tool to create an image (e.g. ISO) of the drive that you can then mount with software.
    Disk imaging tools tend to access the drive at a lower hardware level so could get around any software issues.
    Worth a try...
  13. bartiszon
    bartiszon Minimodder
    25 Aug 2010
    The sector backup before you try to recover any data is a very good advice.
    It looks like this HDD is in poor condition and every attempt to copy can make it worse.
    First you should check how bed it is: keep attention for a strange noises while it starts, then try to get some SMART info (e.g. health status in HD Tune).
    Strange noises (knocking, squeaks or cheeps) - condition of HDD's mechanism.
    SMART - condition of the magnetic surface.
  14. Andy Mc
    Andy Mc Modder
    23 May 2002
    I would recomend Spinrite, as I hear nothing but good things about it. However it is $89 so that goes against it.
