Modding Laptop LCD
Discussion in 'Modding' started by alpha112, 1 Sep 2004.
  1. alpha112
    alpha112 Minimodder
    23 Aug 2004
    I have a laptop LCD working with my PC (bought from Heofz). Its great for videos (cept sometimes it makes my sound scratchy, but I can sort that out later). Does anyone know a good way to mount it so I can put it on a wall (cheaply)? What tools will I need?
    Thanks.
    [Sorry if I sound noobish, but I havent modded anything before]
  2. boe
    boe What's a Dremel?
    16 Aug 2004
  3. alpha112
    alpha112 Minimodder
    23 Aug 2004
    Thanks for the idea that looks rly kl, Ill mite try that.
  4. diskreet
    diskreet What's a Dremel?
    1 Oct 2003
    *PHEW*
    I was going to kill you if you asked how to usa a laptop monitor as a 2nd monitor. we are so sick of that here!
    :search:
    anyway i really like the frame idea, it looks really good. also you could just flush mount it in and spackle/paint it, but that would have to be perfect to like the mm.
  5. alpha112
    alpha112 Minimodder
    23 Aug 2004
    Yeh Ive seen, but I have mine all nicely working in 24bit colour :D (shame the gfx cant do 32 :( ), even after a few problems with my soundcard hogging the PCI bandwidth :wallbash: .
    I think I might make a portable screen, or at least one which I can unhook from a support easily so I can move it away from my PC (a dell :jawdrop: ) which sounds like a small airplane. But not for a little while, so the chair and old trainer arrangement I have at the moment will have to do.
  6. diskreet
    1 Oct 2003
    thats cool. its nice to see someone not ask that question, lol.
    anyway good job on even getting it hooked up! i still like the frame idea though.
  7. fartonmyear
    fartonmyear What's a Dremel?
    16 Jul 2004
    so uh...how do you make a laptop screen a second monitor? :D
  8. diskreet
    1 Oct 2003
    :eeek: where is the b*tch slap smilie?!?!
  9. buchans
    buchans What's a Dremel?
    28 Jun 2004
    had to happen :D
  10. alpha112
    alpha112 Minimodder
    23 Aug 2004
  11. diskreet
    1 Oct 2003
    :rock:
