Hey, As the title says, looking for a laptop around the £400 marker. General use with quite a bit of photoshop but only oldschool CS2. I'm guessing an i5 would be my best bet? Would prefer a small SSD over a larger mechanical drive. Any good deals about? Maybe the dell outlet? Thanks in advance!
Dell outlet then would be worth a look. I doubt for that money your going to get anything bigger unless there is something insanely cheap in the Dell out let that it would be rude to say no. If you were looking at buying something used then it is worth considering a business class HP or Dell Laptop as they have a much better build quality than your standard run of the mill consumer grade tat.
http://www.laptopsdirect.co.uk/refu...2.8ghz-4gb-250gb-w-a1-b5v88aw-1yr/version.asp spend the change on more ram and an SSD
Two places I search. Google for Argos Outlet on Ebay. It will take you to their store front, excellent deals on laptops. You can also try Amazon Warehouse, but be sure you search for anything at full price because sometimes their warehouse prices are like £2 less than the full RRP. Ed. Forgot, Tesco have an outlet on Ebay too.
Yo, this is a pretty good deal huh? And by scratch and dent... its probably just a few scratches on the lid? http://outlet.euro.dell.com/Online/...I1qQtKZYBNMsrbsfhca0Dyzk2CIioDANi/dq3SxF+5rw=
