Notebooks laptop recovery deletes partition?
Discussion in 'Hardware' started by Lineage, 20 Feb 2007.
  1. Lineage
    Lineage What's a Dremel?
    19 Sep 2003
    i just bought a laptop, it only has a 1 drive except the recovery drive. i want to create a partition from c: drive using partition magic. my question is if i use the recovery disc, will it also delete my partition?
    thx
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    It's hard to say without knowing the specific recovery disk. The one I use wouldn't, but I've used others in the past that format the whole drive.
    Best advice is to back your data up just to be sure.
  3. Lineage
    19 Sep 2003
    ok, thx
    btw, i m using dell 6400 with window vista home premium, any experience with it?
  4. Glider
    Glider /dev/null
    2 Aug 2005
    Just not use the recovery disk. Use a regular XP cd with the key that's attached to your laptop, and install everything where you want it. My both laptops (Acers) had a recovery cd that would repartition, and create a 1 GB big hidden partition at the start of the drive, for "recovery" purposes...
  5. Lineage
    19 Sep 2003
    the recovery partition in my laptop isnt hidden, its just like a normal partition, i can access it, but dont think i can modify the files
    thx for that suggestion
  6. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    If you use the recovery CD... it almost certainly will format any partitions you've created yourself (my recovery CD's certainly do) :wallbash:
    But as Glider suggests... if you don't want to lose your new partitions... just use a standard Windows CD if/when you want/need to format the drive next ;)
