Electronics [Laptop screen] How-To???
Discussion in 'Modding' started by white modder, 14 Feb 2004.
  1. coorz
    coorz Miffed
    25 Apr 2003
    2x13 pin headers on a VGA card = VESA feature connector.
    I finished the translation of the Dutch HowTo, awaiting original author's remarks and approval.
  2. coorz
    coorz Miffed
    25 Apr 2003
    You could be very right, 16 colors on a 12" or bigger screen is probably horrible to look at! However it may be a stepping stone to further improvements on this way of connecting laptop LCD's.
  3. Altron
    Altron Minimodder
    12 Dec 2002
  4. sk8ero
    sk8ero What's a Dremel?
    27 Oct 2003
    although it may be low quality, if u have the lcd and card y not go for it, it must be better than a 16x2 lcd running from the printer port, plus like wat has been sed it will be the start to many things
  5. coorz
    coorz Miffed
    25 Apr 2003
    Original Dutch to English Translation Pt.1
    With approval from the original author Sprite_tm, here's the translation.
    The original Dutch thread can be found here.
    Sprite_tm can be contacted at vga2vfb(at)troep.boeitniet.nl
    1)Pick your LCD screen
    Color laptop LCD screens are preferred, if possible from the later
    486/Pentium I period. Remove the screen from the
    laptop and take note of all possible part-numbers from the screen.
    2)Find the pin-layout of your LCD screen
    Chances are that you won't find them at all. That's too bad but ****
    happens. You might try requesting the datasheet from the manufacturer,
    but as far as I know they aren't eager to respond to these requests.
    If you can't find the datasheet you might try to derive the pin layout
    from similar screens. I can't guarantee this'll work though.
    You know your screen is good when it has separate digital inputs for RGB
    signals (in my case each color has three lines, but this could be more
    or less).
    If you see 4, 8 or 16 lines labeled as 'UD', 'DATA' or other (not directly
    color-related terms) lines NOT referring to RGB colors, you can forget
    about it.
    Also check the power requirements of the screen and the voltages of the
    I/O lines (these should be 5 volts; otherwise you'd have to make a level
    converter. If you're not sure about this, you might go ahead but you risk
    blowing up the whole bunch!
    Aside from the LCD screen you will also need to wire up the inverter for
    the backlight CCFL's. Normally that's a small print located next or near
    the LCD that has two or four wires running into the LCD. Without
    backlight, screen contents will be hardly visible.
    3)Find an old VGA-card
    Don't risk blowing up your expensive VGA-card! Get yourselves a cheap
    ISA or PCI card. Make sure it has the VESA FEATURE CONNECTOR (VFC), a
    double row 26 pin header (2x13 pins that is).
  6. coorz
    coorz Miffed
    25 Apr 2003
    Original Dutch to English Translation Pt.2
    4)Trial and error! And fire up that solder iron too..
    Ok, it's time to match the LCD pin layout to the VFC's. It took me
    some time to realize that most pin-layouts found on the internet from
    the VFC are actually WRONG. Here is the one that I found to be correct.
    Next table shows which connections to make between the LCD and VFC
    Don't forget to power both the LCD and the inverter; I'll leave that up
    to you.
  7. coorz
    coorz Miffed
    25 Apr 2003
    Original Dutch to English Translation Pt.3
    5)Connect the whole bunch and be amazed
    If you finish wiring it all up and turn on your PC, you should see
    something on your screen. If not, check the `ENABLE' line of your LCD,
    perhaps that should be on another pin on the VFC. If the screen is not
    stable, try reversing HSYNC/VSYNC line polarity by software or build an
    inverter circuit into the HSYNC/VSYNC lines.
    If the screen is out of center; correct that with software. Alternative
    would be building delay-circuits in the HSYNC/VSYNC lines
    One more thing; this method will only get you 4-bit color (16 colors).
    It should be able to display at least your BIOS settings screen.
    I'd like to thank Sprite_tm for allowing this all :thumb:
  8. pranks7er
    pranks7er mange tout
    25 Dec 2002
    coorz u da man mods i think thoser set of posts should be stickyed!!!!
  9. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    It's Official. By the time I learn enough to decipher half of that, we won't need to go through all this trouble anymore. Very good job on the translation and everything though, I'm sure this is going to be a big help to lots of people out there.
  10. Altron
    Altron Minimodder
    12 Dec 2002
    How to find a datasheet for your LCD.
    Find the model number of your screen, google it, and you may find some LCD shops selling it. They may have data sheets on the site for it, if not then e-mail them asking for one.
    You should make a mod guide for this.
  11. Jenova
    Jenova What's a Dremel?
    20 Feb 2004
    man how hard is it to fine data sheets :(
    what is a standart lcd backlight cathode voltage ??
  12. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    afaik there isn't one. You have to match each panel to a compatible inverter.
  13. coorz
    coorz Miffed
    25 Apr 2003
    Most LCD screens already have an inverter board attached to it. If not, well another hurdle to take then :blah:
  14. Jenova
    20 Feb 2004
    it has its own inverter wit it
    its a sharp lcd screen
    our of an ibm
  15. bradford010
    7 Dec 2001
    In my experience, it's actually around 1 or 2 in 5.
  16. pranks7er
    25 Dec 2002
    if u browseebay u prob can pick up5 reallyold laptopsforabout 50 quid so u can have a few goes if 1 explodes or goes rong or summit
  17. lexx
    lexx Guest
  18. coorz
    coorz Miffed
    25 Apr 2003
    Lookie here
    We need to maintain a database of such sites.
  19. coorz
    coorz Miffed
    25 Apr 2003
  20. bradford010
    7 Dec 2001
    A cookie for the first person to find me soemthing on LM64C149 :D
