Electronics laptop screen
Discussion in 'Modding' started by .:ALOA:., 2 May 2006.
  1. .:ALOA:.
    .:ALOA:. What's a Dremel?
    23 Nov 2005
    sorry, my english is not so good, but i wil tray to expain it:
    i've got een laptop screen: (not so old)
    dus somewone know how i need 2 let it work??
    becose i don't now it :duh: :duh:
    thx
    ps: it is from a toshiba satellite A60
  2. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    I've not tried that myself (yet), but everywhere I've seen this topic come up it seems that it is very difficult to do because you need a special controller.
    This is also mentioned here in the LCD FAQ thread at the top... See post #5.
  3. .:ALOA:.
    23 Nov 2005
    that is expencife :eeek: :eeek: $150.00
    is there not a ather alternetive??
  4. coorz
    coorz Miffed
    25 Apr 2003
    If you have the display's datasheet there's 2 ways:
    - buy a controller as suggested above and if you get it to work you'll realize you were better off buying a second hand LCD monitor
    - the VFC method, quite unlikely it'll work but if you do; enjoy those 16 colors.
    My advice, sell it on ebay and get something nice for the money. Don't waste your time on it.
  5. .:ALOA:.
    23 Nov 2005
    can i sell my 2nd hand laptop lcd??
  6. Nexxo
    23 Oct 2001
    Some people may buy it as a replacement part. Laptop screens are fragile and prone to damage, after all.
  7. .:ALOA:.
    23 Nov 2005
    and how muts will i get do you think??
  8. jet123
    jet123 What's a Dremel?
    17 Apr 2006
    you can never say really, it all depends who wants it when its listed and how much they want to pay...
  9. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Very little.
    They regularly go for $10 - 20 on ebay.
    And please... Use the [size=+2]Fsking Search[/size]. There's a 12 page long topic dedicated to answering laptop screen questions.
  10. gimplish
    gimplish What's a Dremel?
    8 Mar 2006
    can you open up the case and take some pics of the connector on the LCD itself
  11. .:ALOA:.
    23 Nov 2005
  12. Atomic
    Atomic Gerwaff
    6 May 2002
    Simple answer:
    give up.
  13. .:ALOA:.
    23 Nov 2005
    oooow, thx, but i won't :hip:
    if there is no ather way, i will
  14. Atomic
    Atomic Gerwaff
    6 May 2002
    unless you want to spend a small fortune there isnt.
    buy a new flatscreen itd be cheaper :p
  15. gimplish
    8 Mar 2006
    unless you have the dedication to homebrew a converter DVI-->FLATLINK or have something that can output the format i wouldnt bother. the laptop lcd had a LVDS flatpanel chip so i just used that to trace the signals
    im still working on the invertor pinout. unfortunately the only info google turns up for me about the lcd is one of my old blogs which i need to update.
    as you can see also the motherboard on that is hosed
  16. Vequalsir
    Vequalsir What's a Dremel?
    25 Jun 2004
    you might want to look for an industrial display controller. it may have an lcd connection on it all ready for you.
  17. veryevil
    veryevil Minimodder
    14 Aug 2005
    Can you get the make and model number for the lcd (not the laptop) it should be on there somewhere.
    Also how many pins is the connector 20 or 30?
