Modding Laptop Screen
Discussion in 'Modding' started by ErictheHank, 23 Jul 2004.
  1. ErictheHank
    ErictheHank What's a Dremel?
    28 Jan 2004
    I have access to the screen from a Dell Latitude CPX. It's a 14.1 inch screen so I am thinking that it would look quite nice mounted in a computer. Problem is I can't find any schematics or white papers or anything on it. The dell part number is 5264P and the IBM part number is 47L7400. Anybody have any clue how to go about figuring out the pinout of this thing. Is it even possible?
    Thanks in advance.
    ErictheHank
  2. livelife46290
    livelife46290 What's a Dremel?
    19 Sep 2003
    Before everyone else reems you out for this, :search: :search: :search: if you dont care to do that. No its not possible, you need a controller which are expensive, almost as much as just going and buying a new lcd! Just thought i would warn you that im not the only one gonna say this to you, it gets asked often and everyone always gets angry!
  3. ErictheHank
    28 Jan 2004
    My apologies, I did search but I guess I wasn't specific enough with my search terms since nothing in the first 5 pages of results seemed at all relevant. Thanks for the reply.
    edit: changed my search terms and the faq showed up as the 3rd result. My apologies again. Please feel free to lock this thread if appropriate.
  4. star882
    star882 What's a Dremel?
    19 Mar 2003
    Don't give up hope!
    Someone good with FPGA/CPLD design can make a cheap controller.
    And controller boards can sometimes be scored for cheap.
    And remember, you can always pull the controller out of the laptop (good luck actually using it, though)!
