Modding Laptop Size Cd rom
Discussion in 'Modding' started by tm36usa, 3 Mar 2004.
  1. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Do they make a laptop size cd burner that will run on ide?
  2. coorz
    coorz Miffed
    25 Apr 2003
  3. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    coorz indeed said it, I run my cdrw/dvd slim line drive on one of those adapters which cost ~7$ It was as simple as plugging the adapter which rests on the mini-ide connector and then plugging a standard ide cable and a floppy power cable into it
  4. coorz
    coorz Miffed
    25 Apr 2003
    Yeah, and DO shop around for that adapter, shouldn't cost you more than $10. Unlike me who has paid big bucks for 2 of those adapters, damn you Mini-ITX :miffed:
  5. Nexxo
    23 Oct 2001
    However, keep in mind that there is no way to make laptop drives switch from Master to Slave by the simple tweak of a jumper. Most Laptop CD-Roms are Master by default. Some come as Slave. Some can be re-configured as either by re-flashing their firmware. Configuration tends to be done at the manufacturers, who then sell the drives with differing serial no.s: one for each config (Master, Slave, Cable Select) but sometimes you can get your hands on the software and do it yourself.
  6. tm36usa
    21 Jan 2004
    Thanks every one! Will the cd rom and the adaptor be ok on a shuttle 200w psu. There is also gonna be the normal stuff, 2 led fans, lcd, and mabey some ccfl's.
  7. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    I either purchase my adapters on ebay or from http://www.idot.com ($7 each) and I unfortunately do not have any spares left to offer you.
    Getting the drive at a reasonable price may prove more difficult and I recommend poking around on ebay to gather a list of specific drive model numbers.
    If you have anyquestions concerning adapter compatibility with drives you find, just let me know.
  8. Captain Slug
    25 Nov 2001
    Most of the drives I've come across are either in Cable Select mode or Slave. I have yet to come across any set to Master as default.
