Hey guys, just wondering if laptops with built in 3g exists? I'm asking because I want internet access on a laptop but I don't want to be lumered with a dongle! Would you need to pay a fee to a network provider for the 3g service? Thanks for the help guys
not sure you can get 3g laptops because the dongles are network specific arent they ? so however you choose to go with on 3g congtract they will send u a dongle. and yes a monthly fee is needed for 3g internet access and is usually so many Gb and very expensive charges if you go over.
There are some HP, Dell & Sony loptops with 3g built in. You just slide a sim card in to the slot. They're not cheap though (usually on the £1000+ ultra light business machines)
A grand!? Seriously!? Jeez I woulda thought they'd figured out by now that dongles are irritating at best....
It's not a laptop but I have just purchased a EeePC 1005HG/GO off ebay for £170. It doesn't seem to have any reviews yet though but I just took a chance as it was cheap and I only need it for studying online. It has; Full sized keyboard Bluetooth Wi-Fi b/g/n Uses the Intel Atom HT N270(not great but does the job) 1GB DDR2 800 250GB HDD Built in 3G through a HUAWEI E220 internal card(SIM required) Windows 7 Starter Up to 10 hours battery life 1024 x 600 32bit screen Built in Web-cam/video Built in microphone Realtek HD audio USB 2.0 x 3 VGA out GBit LAN The only thing that lets it down is the Intel mobile 945 chipset for GFX. It only scored 2.1 in the Windows 7 Experience Index. For the price I'm very happy with it as I think it'll do everything I want it to.
Cheers Jux, sounds good! I'll check it out. BTW, which part of bmouth u from? I'm from there originally
Have you not got a mobile phone you can use as a modem via usb/bluetooth with any laptop? Or perhaps a phone you can turn into a wifi access point? I use my three pay and go via some of these methods, no problem so far, great speeds.
Get a Dell Studio Get a dell studio 1558 and put an unlocked 3G Card in it. The laptop already has antennae and the SIM Slot built in, it just requires a 3G Card and SIM Card. Depending On spec you can usually get one between 450 to 600 gbp
