Cooling Large quantities of lube
Discussion in 'Hardware' started by Goatee, 15 Sep 2018.
  1. Goatee
    Goatee Active Member
    19 Apr 2015
    Hey,
    Need some advice from you knowledgeable folk on thermal grease as I guess this is some of you know a lot about this topic!
    I'm creating a heat sink with multiple heat pipes running into it. It is made of 5 aluminium blocks each 10mm x 250mm x 50mm bolted together. The heat pipes come in at a right angle then run between each block.
    I want to ensure as good a contact between pipes, aluminium and the case. To do this I am looking for some thermal grease but don't want to buy a fortune of little syringes of CPU paste.
    To this end I am after:
    • Thermal paste that wont set
    • Good thermal conductivity
    • Cheap and easily available
    • Works with Aluminium and Copper
    • Wont give me cancer or some form of poisoning
    • I'm not worried about electrical conductivity as this is just for the heat sink
    My research leads me to try to find something with a Thermal Conductivity over 5W/m K.
    Im leaning towards this: https://uk.rs-online.com/web/p/thermal-grease/7074736/
    Anyone got any other ideas? (Memes are acceptable too)
    Ta
  2. CrapBag
    CrapBag Well-Known Member
    17 Jul 2008
  3. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    MX-4 is my go-to Tim. Have you considered using copper instead of aluminium so you can solder the heatpipes to the rest of the block?
    Goatee and Dr. Coin like this.
  4. Dr. Coin
    Dr. Coin Active Member
    13 Sep 2013
    I was going to suggest GELID Solutions TC-GC-03 as it comes in a pot, but it is only 10g and $30 USD (£23.98 from Amazon.co.uk).
  5. Goatee
    19 Apr 2015
    Will go with the MX4.
    I would liked to have made the sink out of copper but it would have blown my budget
  6. The_Crapman
    5 Dec 2011
    Blimey, even on eBay you're looking at £80.
    What's the heatsink for? Are the heatpipes having direct contact with the heat source? Might be worth seeing if you can find a full teardown of an Asus direct cu cooler, see how that's constructed.
  7. Goatee
    19 Apr 2015
    Its for my build here, its to try to transfer the heat from a 1070. Just finished hacking the Aluminium up to make it.
    Amazon are delivering 20g of MX4 tomorrow for just under £14. Since I brought it its gone from £13.94 to £17.99 so that was nice!
    The_Crapman likes this.
  8. CrapBag
    17 Jul 2008
    You're welcome lol
    Goatee likes this.
