Modding Laser cut aluminum
Discussion in 'Modding' started by Archtronics, 17 Aug 2010.
  1. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Hey
    For my current project I would like to have the front, top, left and right panels laser cut, the front and top will be a solid peice made from 3mm aluminum and the sides will be 1mm thick but I have no clue where to start looking??? or if laser cutting is the best option.
    Any advise ?
    thanks
  2. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Dependant on P+P, MNPCTech (Bill) might be able to help
  3. Jipa
    5 Feb 2004
    Just find a local place that does laser cutting and ask them? Yellow Pages/what have you over there should help.
    Also 1 mm aluminum is extremely flimsy! I made a temporary side panel from that stuff and it's useless.
  4. capnPedro
    11 Apr 2007
    Also look into waterjet cutting and CNC routing.
    1mm aluminium will be flimsy until you put a 90* bend in one end, at which point it becomes rather inflexible.
  5. stuartwood89
    20 Aug 2008
    If I recall, the mammoth that is Aluchill was made from mostly 2mm aluminium, which is what I would go with for anything structural. I would only use 1mm for cosmetic pieces.
  6. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    If your at nottingham trent, which i seem to remember, head down to the workshop in Maudslay Building and ask Alan Chambers to cut it out on the waterjet. :thumb:
  7. Archtronics
    27 Jun 2006
    Oh wow cheers Burnout I will have a look into that, not back at uni till october hopefully I will be aloud in the workshops this year, wasnt aloud as a 1st year any idea on the costs as I dont expect they will want to do it for everyone especially an architecture student :p
    on the subject of 1 mm aluminum its being fitted to a frame so is indeed purely cosmetic.
  8. Archtronics
    27 Jun 2006
    Double post
  9. Burnout21
    9 Sep 2005
    if its a small job and you ask very nicely there happy to help. Also get in super early as it goes nuts down there very quickly.
    Usual cost = free
    They stock a mental amount of sheet aluminium, but don't get crazy idea's they'll happily do a one off if its small, like the front of case in my project. Well that was big but I've known them for 4 years.
  10. Archtronics
    27 Jun 2006
    Thank I will have ask them once I get back and I already have my aluminum so no worrys there.
    Any idea what programs they use ?
  11. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Most laser cutters use Autocad and will prefer DXF or DWG.
  12. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Any laser cutters in London
