Modding Laser Cutting
Discussion in 'Modding' started by randompkguy, 14 Jan 2009.
  1. randompkguy
    randompkguy whats a 5 axis cnc router?
    2 May 2008
    Hi, I need some laser cuts made for my project. I have already called one place, and they gave me an estimate of 250-300 dollars to cut patterns in two 12x24" sheets of acrylic. I for one think that this is way too much, and was wondering if anyone knows a decent place where I could get the job done for around 100?
    thanks!
  2. talladega
    talladega I'm Squidward
    18 Aug 2007
    if they are a large company to for the most part only does large quantity work then they would of course charge alot.
    try finding a smaller company or one that doesn't do large quantity work. I would think they'd charge less.
  3. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    depends mainly on where you are... because you've said Dollars I'd assume the US, so I'd ask Bill at MNPCTech... I got mine done (granted, it was with a router and not by MNPCTech) for £20 ($30)
  4. cc3d
    cc3d It's a mod mod world
    14 Jan 2008
    Where are you located?
    Have you considered water cutting?
  5. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Where are you located, excellent question.
    Have you tried a sign shop? I found out that my brother's friend has a sign shop with a laser cutter. If you're around the bay area, PM me, and I'll try and put you in touch. (I have not idea what they charge.) You can also try tap plastics. Again, sorry, but I don't know pricing.
    I think it may also depend on the intricacy of your pattern and what format it's in. (ie, will they have to do any special programming, or just input your file and is it a circle, or an intricate filigree pattern...)
  6. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Why does it have to be laser cut?? Can't you settle with water or router cutting
  7. theducks
    theducks What's a Dremel?
    9 Apr 2008
    Call your local Epilog Laser distributor and see if they can recommend anyone. I've always found them to be helpful.
  8. randompkguy
    2 May 2008
    Thanks for all the replies!:thumb: I am fine with water cutting. Not sure about routing as the cut layout on the sheet requires the parts to be rather close together. I'm in the states (Maryland to be specific).
  9. Guest-23315
    Guest-23315 Guest
    $300 waaah?? I did a few bits for people around the forums and asked for a fiver.
  10. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    How about Ponoko? If they've already got the material you want it should be fairly cheap, and if they don't you could always email them and ask nicely if you can ship it to them (their FAQ says you can't, but it never hurts to ask).
  11. slisgrinder
    slisgrinder Minimodder
    14 May 2008
    ponoko is not cheap...i am trying to make a reprap and it is stupidly expensive...
  12. Cheapskate
    13 May 2007
    Smells like a bot...
  13. talladega
    18 Aug 2007
    tastes like one too
  14. m00kiechan
    m00kiechan What's a Dremel?
    16 Jul 2010
    Anyone in the Northeastern PA area needing lasering done.
    I have two Epilogs. Call our shop at (570) 823-3726 :clap:
