Other Laser Show Safety and Info
Discussion in 'General' started by QuackMasterDan, 26 Oct 2008.
  1. QuackMasterDan
    QuackMasterDan What's a Dremel?
    26 Oct 2008
    Hello there, I enjoy creating lighting projects to illuminate my house that are enjoyable and are pleasing to the eye. I've been interested in using lasers for awhile, but am concerned about the possible damage to the vision of myself and my house guests.
    I have stumbled across a guide based on creating a laser light show through the use of a laser, mirror glued to a headphone speaker, and a diffraction grating plate (Found @ http://www.gmilburn.ca/2008/07/21/the-ultimate-home-laser-show-parts/). I do not desire an incredibly powerful light show, instead the same process with a much weaker laser that can be left on 24/7 (and not overheat) to light up the ceiling in my living room.
    Safety
    With a 5mW laser (the legal intensity allowed by the U.S. FDA to be owned without a reason) and the laser passing through a diffraction grating, will a guest who looks into one of these diffraction beams (either accidentally or on purpose) damage their vision? As this is intended to be left on 24/7 or mainly at night, it needs to be safe to have in the living room. Are there any precautions I should look into for constructing this project (I am assuming that construction with the single beam will be dangerous, yet diffracted beams will be much weaker)?
    Quality
    This is not supposed to be a distraction in the house, but whenever someone walks into the room at night will see the ceiling illuminated with glowing laser patterns. Is a 5mW laser bright enough to be visible on the ceiling after having passed through a diffraction grating? From reading peoples comments about lasers, many people desire lasers that pop balloons or cut tape (high powered - 50mW+). Can I have a successful show with a laser weaker than 5mW (lower power would be preferable)?
    Heat Dissipation
    From what I have been reading, leaving a laser turned on for continued period can burn out or damage the laser. What kind of lasers can I purchase that can be left on indefinitely?
    Any information would be greatly appreciated, and I am very interested to begin to use lasers for projects.
    -QuackMasterDan
  2. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    As long as a guest doesn't stare at it then it should be ok.
  3. QuackMasterDan
    26 Oct 2008
    When you say stare at it, do you mean 10+ seconds of looking directly into a beam? How big of a difference does the wattage of the laser make?
  4. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Better to say Milliwattage.
    OTTOMH, nothing above 10mW, and you (and your guests) should* be fine with the setup you mentioned.
    Though you should be aware that different colours of light appear brighter than others for the same power level. (532nm green especially, at that's about at the top of the eye's response curve)
    [I was going to point you towards LPF, but you're there anyway...]
    *I am neither a lawyer or a lighting engineer
