  1. Unicorn
    25 Jul 2006
    Just pulled the trigger on a Meguiars G220 V2 dual action polisher and a bunch of accessories for it including pads, polishes and some other detailing bits and pieces. Hopefully this will be my last big order of supplies to get both cars corrected and protected for the rest of the year and probably all of next year too.
    G220 V2:
    Full set of Menzerna polishes:
    • Fast Gloss (FG500)
    • Intensive Polish (IP2100)
    • Super Finish (PF4000)
    • Final Finish (PF4500)
    Also some Meguiars polishes/compounds:
    • Meg’s M105
    • Meg’s M205
    Menzerna foam pads:
    • 2x Polishing pads
    • 2x Compounding pads
    • 2x Finishing pads
    Microfibre pads:
    Wolf's Hard Body Nano Sealant:
    Wheel Woolies:
    Valet Pro wheel brush:
    Poorboy’s wheel sealant:
    Aerospace 303 trim sealant (for wheel arches):
  2. Andersen
    Andersen Brain for hire
    25 Nov 2002
    Just ordered an electronic cigarette starter kit + related bits and bobs.
    Time to drop that smoking habit.
  3. freshsandwiches
    freshsandwiches Can I do science to it?
    9 Aug 2009
    Good luck!
  4. Yaka
    Yaka Well-Known Member
    26 Jun 2005
    my hardly used circulaw saw packed in today after blowing out black smoke. musta only used it 4 times in 4 years.
    got the cheapest one i could i find that didnt feel too iffy. much much miore lighter than my makita. milwakee branded on as well felt good to hold but had smaller blade and no hard case so whent for a dewalt. also the sawdust attachment on it is crap, with the vac hooked up hardly anythings gets the chance to be sucked away the makita i had everything preety much got sucked away
  5. M_D_K
    M_D_K Active Member
    3 Apr 2002
    Technically for work but :p
    HP Microserver N54L
    4x 1TB WD Black drives
    1x 64GB Crucial M4
    2x4GB DDR3
    Slimline Optical drive + bay adapter
    various cables
    Windows Home Server 2011
    Should do the job I want it for.
  6. Weekly_Estimate
    Weekly_Estimate Gives credit where its due
    1 Feb 2010
    one of these
    and one of these to go with it
  7. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Cyclepro cable cutter
    £8.98
  8. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    Those things are awesome, nothing better for snipping through cable ties
  9. suragh
    suragh Derp
    26 Nov 2011
  10. Unicorn
    25 Jul 2006
    They look good, but my heavy duty, near impossible to blunt NWS cutters beg to differ. I've cut thin steel rope with them...
  11. M_D_K
    M_D_K Active Member
    3 Apr 2002
    Link please :)
  12. suragh
    suragh Derp
    26 Nov 2011
  13. Nexxo
    23 Oct 2001
  14. TheStockBroker
    TheStockBroker Well-Known Member
    19 Nov 2009
  15. LithiumDesign
    LithiumDesign 3dsMax User
    23 Jul 2009
    £7.50 from fleabay, now time to get some batteries and film and get shooting :geek:
    olympus xa2 by dan-morris, on Flickr
  16. KidMod-Southpaw
    28 Sep 2010
    LOVE that pen too Nexxo!
    Edit: Actually, everything on the table looks like win. The pen, the plans, the new ruler, the vacuum tube, and the little loupe looking thing! :D
  17. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    All it needs it a red dress and leather boots.
    Ahem.
  18. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    Nexxo, are you building a Babbage difference engine? At least that's what it looks like to me...
  19. Nexxo
    23 Oct 2001
    No, but I am planning a Steampunk water-cooled PC... I'm currently talking to a local acquaintance with access to CNC, I have a brass Aquatube and the vacuum tube is one of a pair of symbol nixie tubes.
  20. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
