  1. mrlongbeard
    mrlongbeard Well-Known Member
    31 Jan 2010
    Some under counter lighting for the kitchen
  2. mrlongbeard
    31 Jan 2010
    Expanding my country tastes
  3. hoochy
    hoochy Need moar cooling
    16 May 2012
    Cake. Misses has started a new job and I though it best to go sample the wares with the dog :)
    Upside down apricot cake with caramelised almond brittle, apparently. All I know is it was nom nom nom nom nom
  4. mrlongbeard
    31 Jan 2010
    Jim Beam Devil's Cut Bourbon : Buy Online - The Whisky Exchange
    I don't normally like Jim Beam, it has a nasty coconut /washing up liquid taste to me, but this was on sale and it's not a bad drop, maybe a touch too sweet for a regular drink but still nicely smokey and oakey.
    Would love to know the process or if it's BS, but for now it had been added to the occasional tipple list.
  5. Unicorn
    25 Jul 2006
    All manifold studs on the 3S-GTE and most other Toyota engines are E-TX/External Torx/Female Torx, as are some of the hub bolts on the Clio, so I ordered a set of Teng Torx sockets:
    I have a good 3/8 set of my own, but the only 1/4" drive ratchet I've had access to is Dad's old Hilka one which is probably as old as me (no joke) and wilst the sockets are still fine, the ratchet itself has seen better days, and is very difficult to change direction on as a result of wear on the mechanism, so a new one was in order. The Teng set was on special offer with about £30 off. Some people rave about Teng, some professional mechanics find them too weak over time and state that they're over hyped. For anything I'm going to be doing though, they should be fine:
    I've also been after a set of combination spanners with ratchet rings on them, so I opted for the Wera Joker 11 piece set:
    I'd been eyeing the Blue Point/Snap-On set with a ring on each end of different sizes (for compactness in your toolbox) but at more than twice the price of the Joker set, I decided against it. Wera are good quality and have a good warranty as well, and the Joker looks to be a very useful tool.
  6. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    the efforts of a concept artist.
  7. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    A few things while on Honeymoon/family Vacation in Germany:
    An Orange Micro Terror. 1) Because it's tiny and cute. 2) because the cleans sound amazing
    Some Clothing
    Loads of Beer
    Loads of food (I must have put on 5 kg over there)
    The full Lego TMNT Keyring set (why no Splinter and Shredder, Lego???)
  8. KidMod-Southpaw
    28 Sep 2010
    Those micro terrors are epic little heads!
  9. Lance
    Lance Ender of discussions.
    6 May 2010
    OK. Talk to me.
    1, how are they powered? Can you have them wired into your home lights or do they need to be plugged in? I would love to be able to switch them on with my main lights.
    2. If plugged in how discrete is the plug?
    3. Did you get the extentions? It says that you can do 5m + 3m which is what I need but did you have a chance to test that?
    I am very tempted to go and get these....
  10. mrlongbeard
    31 Jan 2010
    1, I mostly use electricity to power them :thumb:
    2, Reasonably discrete, will post a piccie up tonight
    3, No, I only needed a shade over 4 meters in the end
    1 serious, It's a standard 3 pin transformer plug.
  11. SuperHans123
    SuperHans123 Well-Known Member
    27 Dec 2013
    Polaroid Cube.
    Awaiting delivery late September from PhotoJojo.
    Massively excited.
  12. Lance
    6 May 2010
    Cheers longbeard.
    I'm thinking of ordering two and having a play before installing it all.
  13. kenco_uk
    28 Nov 2003
    Or, install them and then have a 'play'.
  14. Scroome
    Scroome Well-Known Member
    26 Apr 2011
    A wedding. I just paid off my wedding.
    I will now assume the foetal position and suck my thumb............
  15. Porkins' Wingman
    Porkins' Wingman Can't touch this
    23 Feb 2008
    ...and what I need to know is, is there a switch on the lights somewhere, or do you have to turn them on and off at the plug?
  16. mrlongbeard
    31 Jan 2010
    Plug / transformer
    Teeny tiny control box / ir receiver, you can also see my scratty double sided tape as the supplied adhesive tape is a tad poor.
    You can put them into standby via the remote but to properly power down it's turn off at the socket.
  17. stormbringer500
    stormbringer500 New Member
    6 Jan 2010
    Arrived this morning :D Nexus 7 32gb.
  18. legoman
    legoman breaker of things
    28 Feb 2010
    some brake parts and hose both in red
    Some bar ends for the trainer bike, i'm a sucker for carbon
  19. Unicorn
    25 Jul 2006
    Mmm, tasty brake lines. What are those going on?
  20. BentAnat
    26 Jun 2008
    Yes, they are... Now to convince my better half that I really need a 2-channel high-gain Orange. Preferably a Rockerverb 100.. .:p
