  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Used them now twice at gym and best £20 I have spent in a long time
  2. Tangster
    23 May 2009
    20kg weight vest to help with bodyweight exercises. Came with a free skipping rope.
  3. Lance
    Lance Ender of discussions.
    6 May 2010
    You want to skip in a 20kg vest.
  4. Kovoet
    26 Aug 2009
    My monthly supply.
  5. jinq-sea
    15 Oct 2012
    And what grinder, pray tell, will that reside in? :)
  6. David
    7 Apr 2009
    I'd guess it's more likely coffee than angle or bench. :lol:
  7. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    Who thought that was a suicide vest at first?
    *raises hand*
  8. jinq-sea
    15 Oct 2012
    Indeed. I have just noticed a word missing from my post. I meant to ask which coffee grinder haha!
  9. Mister_Tad
    27 Dec 2002
    Not the grinder you may think, actually. I've got a modded Kitchenaid Artisan.
    It's just an okay grinder in stock form, but with a stepless mod, a bit of tinkering so that it clears the grind chamber a bit better and a mod to accept mazzer burrs nothing short of stellar IMO.
    I keep eyeing up the Mazzer Mini Electronic, Type A, shiny polished of course... I figured I'd give the current grinder a bit of a refresh though, since I noticed the burrs were no longer quite as sharp as they used to be. Hopefully it's enough to keep my upgrade-itis at bay for a bit longer...
  10. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I love those Zero guys. They are the only thing that stop be getting dehydrated riding my bike in the summer.
  11. jinq-sea
    15 Oct 2012
    Oh nice - are they well-documented mods? I have a very old Gaggia grinder, very much like the current MDF range, which needs a bit of TLC to be honest (or replacement, I guess). The thing is, it matches my similarly old Gaggia machine which I have a) had for a long time; and b) love.
    I've never even contemplated changing the burr in the Gaggia for something more substantial, but that's certainly got me thinking!
  12. Mister_Tad
    27 Dec 2002
    It's a very simple design, so quite easy to open it up and take the grind mechanism apart and tweak. I did the stepless mod before ever reading about it anywhere, but it's pretty popular. The burr swap needs a few holes drilling and tapping, since the stock burrs are 2 hole mounts and the Mazzer ones are 3x holes, but it's well worth doing, I've seen conversion kits too, which make it a little simpler. The stock burrs don't so much grind the beans as crush them, so espresso can be a little inconsistent and muddy. The Mazzer burrs are thicker than the stock burrs though, so the sweeps that clear the grind chamber need either extending, or the back of the grind chamber needs shimming out, either is fine.
    The KA does have a few things going for it...
    - looks for starters, easily the highest WAF of any electric burr grinder out there
    - The motor speed is a leisurely 450rpm, so no risk of burning the beans
    - The bean to ground path is a whole couple of cm, and the design really limits places stale grinds can get caught
    - Hopper and basket are glass, so no static issues
    It's not perfect though. I've read some reports that the outer burr can wobble quite a bit for an inconsistent grind, I've not had such an issue, but I do hold the dial firmly whilst grinding just in case. Grinding on-demand is a matter of guesswork as well, as there' no timer or anything of the sort. Experience has taught me to get the dose bang on most of the time by eyeballing it though.
    The mods really put this grinder in a much higher weight class, hence the upgrade path for me skipping straight over mid-priced favourites like the Rocky in favour of the Mazzer, even then I'm concerned that I'll be deflated after the outlay.
  13. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Bought 2 used softball bats last night.
    A 28 ounce Worth Legit Resmondo
    A 27 ounce Miken Psycho SuperMax
    Retail both are 299.99 plus tax new, he wanted 120 each, but since a lot of buyers fell through, he sold em both for 200. One needs to be re gripped, but they're in pretty good shape (he said 1 season of use on them).
  14. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    Galax GeForce GTX 970 EXOC Black Edition
    my 7970 died today after two week long battle with random crashes/artifacting
    my last nvidia card was the EVGA GTS 880 320MB :D
  15. Kovoet
    26 Aug 2009
    Got a couple as a sample once and now for my cardio work best things ever.
  16. Nexxo
    23 Oct 2001
    I just have a £20,-- Hario Skelton/Kyocera ceramic coffee grinder. :p It's a simple hand crank, but it does a good job and you can get several mods for it.
  17. Mister_Tad
    27 Dec 2002
    I keep thinking I should actually pick up a Hario... most of my friends and colleagues end up asking me for coffee related advice, and the Hario is my go-to grinder recommendation because most people tend to leave it as an afterthought... i.e. "I've just spent £300 on this espresso machine, what grinder would you recommend for under £50..." :duh:
  18. Cei
    Cei pew pew pew
    22 Mar 2008
    Happy 30th Birthday to me!
  19. Lance
    6 May 2010
    All the coffee stuffs
    I have a Hario compact, which I think is great. I think it takes a little longer to grind, but for the office its perfect.
  20. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    It would really annoy me that the mask would be upside down when the screen is open.
    Notice any difference compared to the regular 3DS XL? and how is the extra thumbstick/nub?
