  1. Instagib
    Instagib Minimodder
    12 Mar 2010
    Pentacon made some really under-rated lenses back in the day. I have this:
    Pentacon 135mm f2.8. On any of my MFT cameras its about a 270mm f4 or thereabouts. Mounted on my GM1 like above, and its an awesome, compact, sniper rig. I love it. Downside is though its not amazingly contrasty, but I correct in LR for that anyway.
    I think it cost £25 a year ago.
    Yorkie likes this.
  2. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Here you go chaps, still a few bits to add but it is getting there.....
  3. Pliqu3011
    Pliqu3011 all flowers in time bend towards the sun
    8 Aug 2009
    Rollei Planar 50mm 1.8 (AKA Voigtlander Color-Ultron) on a Rolleiflex SL35
    After a bit of cleaning and some lubrication (you would not believe how much sand was in the helicoid of this lens...) it works beautifully again.
    Though I've only had it for a few days this is quickly becoming my favorite normal lens (well, short tele on crop sensor to be correct). The rendering is just extraordinary.
  4. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Got a little bit too excited over this.
  5. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I know what my next case is gonna be.
  6. Pookie
    4 May 2010
    It's certainly something a little different from Dell/HP's etc offerings. In my opinion this should last longer, and be easier and cheaper to maintain and service over the years too.
    The Start Tech Hot Swap bay's deserve a special mention just for the excellent build quality and ease of installation.
  7. Ending Credits
    4 Jan 2008
    Are there any more consumer-focused rackmount cases? I would need it to be enclosed on 4 sides (I could buy a rack I guess, or build a super awesome desk).
  8. Pookie
    4 May 2010
  9. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    http://www.xcase.co.uk/
  10. JaccoW
    JaccoW Overspender on keyboards
    30 Apr 2009
    Since we are all posting our latest vintage lenses... :p
    It's the 1:1 Macro adapter for a Minolta 100mm F4 macro lens I bought last december. The lens itself was a steal because of a dented filter ring but was still functioning perfectly.
    With the 1:1 adapter I can get insane detail. (FYI 1:1 means that 1cm translates to 1cm on the sensor itself. Meaning that a Full Frame sensor can be filled with a 36x24mm area and still be sharp.)
    Anyway:
    Without 1:1 adapter
    With 1:1 adapter :D
  11. asura
    asura jack of all trades
    22 Apr 2009
    What do you plug your Minolta glass into JaccoW? Other than the 50mm f1.4 that's probably my favourite lens... maybe the 24-50mm f4...
  12. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    My wife has wanted a portrait of a cat she had a while back and we finally got around to getting it done:
  13. Craig_T
    Craig_T What's a Dremel?
    2 Aug 2014
    Decided to buy a Micoserver to upgrade from my current Synology NAS...
  14. JaccoW
    30 Apr 2009
    Just a good old Sony Nex-5... yep, the first generation one from 2010. With the right lenses it still performs great. :thumb:
    I need to get my hands on the 50mm F1.4 Rokkor-X some day and then decide what I want to do with some of the older M42 lenses I have. The bayonet mount of the Minoltas still work great.
    Don't discount the 135mm F2.8. That one is still one of the sharpest lenses I own.
  15. TrevDX
    TrevDX Ah Who Cares Anyway???
    9 Aug 2011
    3 day ticket to London MCM expo, my first ever con!
  16. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Too many things:
    Glossy photo paper, 50 sheets
    5 for 99p, or 1 for 99p; got to love ebay...
    Nerf Elite Alpha Trooper
    Nerf Raider shoulder stock- compatible with the above
    Spring upgrade kit
    Rotary encoders, to try and fix my knackered FUNC MS-3; should hard to screw up the fairly basic replacement procedure but we'll see... :worried:
    3mm Styrene ( HIPS ) A4 sheet
    2000W heat gun, for shaping the above & any other thermoplastics
    Matt white spray paint
    Grey primer spray paint
    Ceiling rose
    E27 to B22 adapter
    4 way E27 adapter
    8W warm white LED bulbs x4
    The above 4 items will be mashed together to create a wondeful new ceiling lamp in my bedroom... :D
    Angled foregrip, will be melded to the foregrip on the AlphaTrooper for a better handhold.
    30mm x 5mm x 200mm Aluminium bar
    Phew...
  17. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    On offer @ HH, so why not;
  18. Yariko
    Yariko What's a Dremel?
    26 Jul 2010
    Can we see the finished product when it's ready?
  19. Gareth Halfacree
    4 Dec 2007
    The old-version (now retired) Leatherman Juice S2. I prefer the plain scales to the 2014 model's sculpted scales, y'see. It's to be my daily carry, as my (much, *much* nicer) Leatherman Charge Ti has locking blades and therefore doesn't get an automatic pass from S.139. Pretty impressed with it so far: the high-carbon blade takes a nice edge, and the slipjoint 'lock' holds it in place reasonably well given it's a non-locking tool. The pliers seem a little stiff, though, and the flat-blade screwdrivers can be a bit of a swine to get out.
  20. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Getting ready for softball season. 200 for the team, jerseys, etc.
    12 bucks for these high socks (the blue ones on the bottom, store didn't have the navy).
    Jerseys will be a royal blue (slightly darker than the Toronto Blue Jays blue) with some grey and white in them. Logo is as seen here! It's going to be in white on the blue jerseys. :rock:
    For anyone curious about the font, it's called Bulletto Killa and it's available on dafont.com
