  1. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Replaced the car.
    2010 Ford Focus Zetec S.
    Picking it up Wednesday :)
  2. Unicorn
    25 Jul 2006
    A couple of oil cooler kits. One has most of what I need, the other has some of what I need. I'll Frankenstein the kit I need out of them and sell on what's left.
  3. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    They look like good watercooling radiators...
  4. Umbra
    Umbra New Member
    18 Nov 2013
    Hi, I've only had this TV a few days but I've checked all the channels even ones that I would never normally watch and there is no audio delay on any of them, I'm using default settings audio format PCM, audio delay 50.
    Can't help with Plex as I have not used it and only have a basic BR player connected at the moment, there is a firmware upgrade available but it does not explain what issues it may fix but might be worth a try, you could also try posting on the AV Forum sorry can't be more help.
  5. bawjaws
    bawjaws Well-Known Member
    5 Dec 2010
    Unfortunately, lip-syncing problems seem to be quite common on Samsung TVs when watching using the built-in tuner. Definitely check that you've got the most recent firmware on there.
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Ah, that's where I'm going right, then. I only use a Sky box or stream via Serviio (Another media streamer like Plex).
  7. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    Does that stuff actually work?
    I managed to get a 30g tube of MX-2 for the price of the 10g tube last year! So im ok for a bit, but i have always been tempted by the cheap stuff!
  8. Big Elf
    23 Apr 2009
    Yeah, I updated the firmware a few days after setting it up. My audio settings were the same and set to an Audio Delay of 50 but after resetting the sound the delay went to 140. I've retuned it a couple of times and the last one improved it with less apparent lip sync problems. I've also double checked that I'm receiving from the correct Transmitter (Sudbury). However I think to get it right on Channel 12 it would have to be a negative number on the Audio Delay which can't be right and presumably would then cause problems with the other channels.
    I'll get in touch with Samsung and RMA it if there's no fix.
  9. mrbungle
    20 Sep 2004
    Works absolutely fine.
    Use half decent stuff on my Haswell rig but all the rest get the cheapy stuff :)
  10. Guest-23315
    Guest-23315 Guest
    As long as they don't have aluminium cores.
    Heater cores and radiators like these were the norm for WC'ing back in the early 2000's..
  11. Guest-23315
    Guest-23315 Guest
    £20 worth of Chinese
    3 bottles of Tiger.
    Come at me Sunday night.
  12. Yorkie
    Yorkie Active Member
    22 Jun 2010
    Just a few random tidbits
    To go with my other ones
    I bought an actual CD it feels weird
    Because my bike go boom
    And because I need to cut my hair
  13. Mister_Tad
    Mister_Tad Super Moderator Super Moderator
    27 Dec 2002
    Arg...
    That's definitely the last one now. The only place I can go from here is to add a zone in the garage, and utility room, maybe the hall, perhaps all four bathrooms... ok so maybe it's not the last one :worried:
    ~£125 on Amazon.es at the moment for anyone that cares to join us. JOOOOOOIIIIIIIIIIINNNN USSSSSSSSSSSSS.
  14. jinq-sea
    15 Oct 2012
    Stop it. Now. I will end up with a zone entitled 'Porch' at this rate.
  15. Umbra
    Umbra New Member
    18 Nov 2013
    Bought a swivel TV stand as my new TV has a fixed stand, I'd like to say 'It's a great stand and worth every penny' but actually, it's easily the biggest pile of junk I've ever bought and I've bought some junk in my time!
    This purchase has been farcical, it should have been delivered last week but wasn't and the ebay seller, who has sold 100's of these stands (wonder how many were returned?) took until today (13-4-15) to reply to my inquiry and said 'Sorry for delay it's because of Easter holiday' What...that was a week ago :confused:
    They provided a parcel force tracking number which showed there was no one home when they tried to deliver and had left it at a post office last week, but I was home and besides they never left a 'sorry we missed you' card?
    I went to the PO and got the parcel and noticed the house number for my address was wrong, so parcel force had tried to deliver to the wrong house, amazing, it just keeps getting better and I wasn't really surprised when I opened the parcel, which sounded like a pile of glass and metal falling around inside a cardboard box, to find a pile of glass and metal falling around inside a cardboard box, packing materials, nil, damage, quite a lot.
    Nice dent in this piece
    and this plate is supposed to fit inside the channel and support the TV!
    Amazingly, the glass was scratched but wasn't broken, I think the safety glass was all that was supporting the cardboard box, one part didn't quite match the piece shown on the stunningly detailed and lavish assembly instructions which were a masterpiece in nano printing and fitted neatly onto one side of A4, but which must be the part as there were no others which vaguely resembled it , it was too big and didn't fit, so it was impossible to assemble the stand...Hmm, I'm starting to get a bad feeling about this, it definitely looked better in the pictures, time to open an ebay case :rolleyes:
    Incredible work, I'm sure there are full assembly instructions here some where, probably just hidden in a micro dot for security reasons :worried:
    Oh yeah, You might want to avoid buying one of these unless you are a masochist, in which case you could probably turn it into a personal torture device, just don't consider using it for a TV stand or you will be disappointed :sigh:
  16. Mister_Tad
    27 Dec 2002
    Oh snap! I didn't even consider outdoor zones. Doing up the garden either this summer or next, and there's bound to be three distinct lounge, eat/cook and play areas out there as well.
    Fortunately the max device count of 32 isn't enforced and instead is a QA limit with specific regards to SonosNet :D
    That said, I think I can only get to around 25 before I cross over from silliness to genuine stupidity... or get a much bigger house.
  17. mrlongbeard
    mrlongbeard Well-Known Member
    31 Jan 2010
    New keyring
  18. SuicideNeil
    SuicideNeil New Member
    17 Aug 2009
    For my Dad, his original aerial is snapped inside the rubber/plastic coating, causing very poor reception. Based on a quick search it seems these stubby antennas work just as well as the original, but look much better.
  19. Mister_Tad
    27 Dec 2002
    I'm glad you put some descriptive text along with that image.
  20. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Just pledged for the next volume of Girl Genius on Kickstarter.
