  1. Guest-23315
    Guest-23315 Guest
    How many inches?
  2. Big Elf
    23 Apr 2009
    Xiaomi Redmi Note 4, amazing phone for the price.
  3. Mister_Tad
    Mister_Tad Super Moderator Super Moderator
    27 Dec 2002
    Total length is 10 inches. It's reassuringly thick too.
    In summary, I have a thick, smelly 10" black rubber strap on. Or at least I did this morning, it's in the box with the rest of the collection now.
  4. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    Dell XPS 13 with 7th-Gen Core i7-7560U (2C/4T with Iris Plus 640 graphics, the one with 32MB eDRAM nobody ever knows how to use), 16GB DDR3, 512GB SSD, 13.3" Full HD display, and Commie Ubuntu Linux 16.04 LTS. No longer will I have to suffer through macOS being macOS!
    Now I just have to make sure I can book enough extra work to pay for the thing, 'cos despite finding a £100-off voucher it was still north of £1,400...
  5. Mister_Tad
    27 Dec 2002
    Ooh, is that shiny gold/bronze I spy as well? Very nice.
  6. Gareth Halfacree
    4 Dec 2007
    Stock image - I actually have no idea what colour the one I've ordered is, as it only shows it from the front while open and there was no box to tick to change it.
  7. Mister_Tad
    27 Dec 2002
    *receives pink/green striped XPS13
    *realises he should have checked the fine print
  8. Gareth Halfacree
    4 Dec 2007
    I would be OK with this.
  9. Guest-16
    Guest-16 Guest
    The, urm, 5 is out next month..
  10. Big Elf
    23 Apr 2009
    At £108 shipped for the 3GB/32GB Global version?
    The wife needed one fairly quickly to replace her old phone.
  11. Guest-23315
    Guest-23315 Guest
    I didn't know they did anything bar the standard (and fairly nice) anodised Silver.
  12. Kronos
    Kronos Well-Known Member
    6 Nov 2009
    I got one of these also great phones.
  13. yuusou
    yuusou Well-Known Member
    5 Nov 2006
    Ordered these o-rings for my keyboard.
    2.5mm 40A
    It's just at the limit of MX speed actuation and should make the keyboard nice and quiet.
    After years of laptop keyboards, the clankclank was a bit much.
  14. jrs77
    jrs77 Well-Known Member
    17 Feb 2006
  15. Kronos
    6 Nov 2009
    My B&D VPX1222 is getting a bit tired though it has served me well, but with a couple of new batteries going to cost over 50 quid it was time to look for something else. The Bosch PSB 1800 LI-2 was well reviewed so went for it.
  16. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Thinking about this for my 1080, can you keep the backplate on? that is a deal breaker for me
    LennyRhys likes this.
  17. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Good question!
    Short answer: yes you can (and the frontplate too). This was the very reason I went for the Morpheus because I believe that the Arctic Xtreme cooler would not have fit with the PCB cooling plates still in place.
    Long answer: upon installation of the Morpheus, I found to my utter astonishment and frustration that Raijintek have changed the mounting system for the Morpheus in its new guise (the Morpheus II). Instead of a simple system of four spring screws, there is now a retention bracket similar to what you'd find on some CPU coolers and four much longer spring screws. Ugh. So as long as you can put something in place of the bracket, you'll be fine - I tried a few things, and eventually settled with deez nuts which sit perfectly inside the 980Ti's backplate.
    Here's the backplate - it's a big, chunky beast with a thick rubber pad on the contact side.
    And here's my solution - nuts that were about 4mm high, just perfect for the job.
    Despite the (minor) hassle of circumventing the backplate problem I'd strongly recommend the cooler. Still bugs me that they changed it though... if it ain't broke, don't fix it people.
  18. Guest-23315
    Guest-23315 Guest
  19. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Halloween as Duffman? :p
    Topic - I ordered the first new Dan Dare collection since early 2011, out in 3 weeks.
  20. crazyg1zm0
    crazyg1zm0 Well-Known Member
    20 Feb 2007
    Needed a Larger Messenger bag for work. so Spent a bit of time looking around and got my self a 511 Tactical Lima Rush Bag.
