  1. Gareth Halfacree
    4 Dec 2007
    The Pi Hut and ModMyPi are the two current stockists in the UK.
  2. stonedsurd
    11 Mar 2009
    WOW, is it just me or are rental cars stupid cheap in the UK? Managed to get a five-day rental for as much as one day cost me this summer in Italy.
    Fingers crossed for the roundabouts.
  3. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    As Gareth has pointed out, got mine from Pihut.
    I'm only using the Pi for TV/DVR via the TVHeadend channel in plex. My actual plex server is much more powerful.
  4. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    So do you just have the pi setup for the TV/DVR part and is it then passed over to your plex server via the network? I saw these hats and was thinking about grabbing one and then pointing the pi to my plex server.
  5. Guest-44432
    Guest-44432 Guest
    Maybe I'm mad, but I bought a 9900K and Gigabyte Z390 Master Motherboard.
    The_Crapman likes this.
  6. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Do not use your indicators, it'll be taken as a sign of weakness
    Arboreal and Mr_Mistoffelees like this.
  7. Arboreal
    21 Jan 2011
    Showing my age and childishness here... :grin: @2 min 13 sec - I can't get the time link to post
    Vault-Tec and The_Crapman like this.
  8. adidan
    25 Mar 2009
    :jawdrop:
    Fair play Si. You want it, you get it. You nutter :lol:
    Guest-44432, Arboreal and The_Crapman like this.
  9. 13eightyfour
    9 Sep 2003
    Pretty much, the Pi is connected to the network and TV aerial that's it and It runs Tvheadend. Adding the LiveTvh 'channel' to Plex means that I can view anything it picks up live. The DVR side of things is a little more 'janky' the recordings are done through the web, but I've got a few series linked for download which works fine, they do need to be downloaded into a folder manually for Plex to access them though. Not perfect but it does work and seeing as we don't really watch a lot of normal TV it suits our needs perfectly fine.
  10. Guest-44432
    Guest-44432 Guest
    Haha, I guess I will never change... Lol
    adidan likes this.
  11. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Just have the recordings save automatically in a folder which you then add as a TV type library...?
  12. 13eightyfour
    9 Sep 2003
    That is ultimately what I wanted it to do, and admittedly I've not had much time to look into the various options but on first glance, there is no default download folder for the web client, it simply opens the system save settings when you select download selected recording.
    When I get time I'll dive into the options on the actual Pi because they have to be saved locally on that, so there must be an option to change the download folder.
  13. Zoon
    12 Mar 2001
    Yeah no doubt they are saved locally and you could have a rsync script to copy the folder over or have it scp each file (use certificate based auth) in the folder and delete the local one off the pi.
  14. stonedsurd
    11 Mar 2009
    I drive in India mate. My default setting is "indicaterz? wots that?"
    mrlongbeard, Arboreal and adidan like this.
  15. adidan
    25 Mar 2009
    I've never driven in India but I get the impression that the general rule is that if it's bigger than you get out of the way?
    Not a bad rule. :)
    stonedsurd and Arboreal like this.
  16. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    If it's bigger or goes moo then it has right of way. Got a friend over in Nepal at the moment and he is doing a charity ride into India today. It'll be mostly Royal Enfields (of course), but my mate will be on a Harley that he managed to find out there. He's done it before and ridden on some scary roads in the Nepalese mountains, but he still worries about Indian roads.
    stonedsurd and adidan like this.
  17. crazyg1zm0
    20 Feb 2007
    New paintball gun, its 1 of a kind with the custom Anodising work done to to. with a Mactching Mechanical frame so i can do either normal tournament electronic modes or i can swap the trigger from to go back to a normal version.
    In love with this gun, used it all sunday at a 10-man event and and will be using it again next sunday at the next event
  18. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  19. stonedsurd
    11 Mar 2009
    Motorcycle riding in India is absolutely harrowing. Would not recommend, except perhaps on holiday in some easygoing place like the backwaters of Goa, Kerala, Pondicherry and the like.
    Or if it's driving down the wrong way, or if its waving a firearm, or if its...
    Defensive driving in India is worthless. You've got to drive like you've got the biggest swinging jackhammer on the road, or you'll never get anywhere.
    adidan likes this.
  20. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    After watching the short stints of Top Gear's India special that were on busy roads. Yup. It looks mental, and like a great way to have a lot of accidents.
