  1. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    2 x Glorious Model O + replacement pads.
    And this:
    Yaka likes this.
  2. adidan
    25 Mar 2009
    99% of the rules of buying anything :)
    Goatee likes this.
  3. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
    Got these for $60 CAD. Everything works. Granted it's used but they work quite well. Now I can race properly on PC instead of Keyboard and mouse! Logitech G27
    B1GBUD likes this.
  4. Goatee
    Goatee Multimodder
    19 Apr 2015
    I think I ID'd the fans.
    PF40561BX-000U-S99
    Size / Dimension Square - 40mm L x 40mm H
    Width 56.00mm
    Air Flow 31.7 CFM (0.888m³/min)
    Static Pressure 3.600 in H2O (896.8 Pa)
    Bearing Type Ball
    Fan Type Tubeaxial
    Features Auto Restart, PWM Control, Speed Sensor (Tach)
    Noise 67.9 dB(A)
    Power (Watts) 16.68W
    RPM 18000 RPM
    I don't think I will be using them in a PC in the lounge......
    Although, they have PWM, so I could run them at 10%.....
    Yaka likes this.
  5. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Holy ****!
  6. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Maybe use them to dispose of your enemies?
    The_Crapman likes this.
  7. Goatee
    Goatee Multimodder
    19 Apr 2015
    Yeah, they are a bit mental. £27.40 each in the UK. I might just have to run them full blast off a PSU @ 100W :)
    Wood chipper style!
  8. David
    7 Apr 2009
    You could use em for making smoothies.
    18,000 RPM and 67.9 decibels is right up there with a Nutribullet.
  9. Guest-44638
    Guest-44638 Guest
    18K RPM was the rev. limit of F1 cars, pre-hybrid... that IS loud.
  10. Goatee
    Goatee Multimodder
    19 Apr 2015
    I think 6 of them will be ~75db.
  11. Guest-44638
    Guest-44638 Guest
    Still not Concorde at take off loud, so that's a small blessing :)
  12. Mr_Mistoffelees
    26 Aug 2014
    Many years/decades ago (1970s) I was taken to Farnborough Airshow. Concord flew a slow flypast which was not just deafening, it was painful loud. Any fan that gets close to that should be burnt.
    Guest-44638 likes this.
  13. Vault-Tec
    30 Aug 2015
    Xiaomi Black Shark.
  14. The_Crapman
    5 Dec 2011
    Do do do do do do.
    Byron C and Vault-Tec like this.
  15. Gareth Halfacree
    4 Dec 2007
    Admin Panel -> Ban User -> @The_Crapman -> "You know what you did."
  16. Guest-44638
    Guest-44638 Guest
    He used 6, not 5... he just omitted the commas, after each pair. :p
    *recounted*
    OK, both are 6... but I think he meant the Jaws version.
    EDIT:
    If he didn't mean the Jaws version, I second the ban. :D
  17. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I still have no idea how a shark can hold a cello, let alone play it! :worried:
  18. Guest-44638
    Guest-44638 Guest
    Wait... is even the Jaws version a bannable offense...? I was thinking of another - equally bannable, IMO - variant. o_O
  19. David
    7 Apr 2009
    Um....??
  20. Vault-Tec
    30 Aug 2015
    Eddie Murphy - "and then a big brown Shark came"
    /thread.
