  1. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    Careful. For £3000, he'll put his knob on it.
    adidan, perplekks45 and Byron C like this.
  2. MLyons
    MLyons Half dev, Half doge. Staff Administrator Super Moderator Moderator
    3 Mar 2017
    I heard he's much cheaper than that.
    adidan likes this.
  3. Byron C
    Byron C Probably isn't Hitler, but definitely a muppet
    12 Apr 2002
    I'd do it for £300, personally...
  4. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Twiddly or Rubbery?
    Also, in the vein of the topic:
    Ikea Alex x2
    Ikea Billy/Oxburg x1
    Ikea Gnedby x2
    Power strips xmany
    EU plugs for converting things to EU plugs.
  5. Arboreal
    Arboreal Well-Known Member
    21 Jan 2011
    Back at the office, now able to put a link in.
    J-Hack Power Accessories.
    As mentioned, I'm considering losing the evil 24 pin cable for their M2427 set - $39 not $50
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Were you aware that Intel are planning to take PSUs 12V only from next year (Just for OEMs at first), moving the 3.3V & 5V to a DC-DC convertor on the motherboard?
    Sauce:- https://www.tomshardware.com/uk/news/atx12vo-12v-only-power-supplies-psus
  7. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    Had a proper splurge:
    Sony WH-1000XM3s
    . Considering that the most expensive headphones I'd ever bought prior to this were £30 (Sennheiser CX300 massif represent!), they're just a weeny bit of an extravagance. Bloody lovely, though: being able to press a button to switch between complete noise cancellation and cancelling everything *except* voices is a revelation, and the gesture-based thing where you clamp your hand over the side to immediately drop the playback volume and pull in amplified external audio is genius.
  8. Vault-Tec
    30 Aug 2015
    High end headphones are totally what they are cracked up to be. If I go from Beyer to Beats I cry a little.
  9. Mr_Mistoffelees
    Mr_Mistoffelees The Cat Lies Down on Broadway
    26 Aug 2014
    Absolutely agree. Just need to make sure you have a good source to drive them with.
    Vault-Tec likes this.
  10. Mister_Tad
    Mister_Tad Super Moderator Super Moderator
    27 Dec 2002
    Earbuds fo' life!
  11. adidan
    25 Mar 2009
    Damned right I can.
    Damned right I would.
    Damned right I am.
    Mr_Mistoffelees, David and Mister_Tad like this.
  12. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    There's a sale on at Screwfix. So far I've bought:
    2 x IRWIN QUICK-GRIP HANDI CLAMP 2" (50MM)
    Because you can never have enough clamps.
    MAGNUSSON MINI PLIERS SET
    These are all sprung, feel nice and also comes with a pretty solid but awkward case.
    MAGNUSSON RATCHET WIRE STRIPPERS 8"
    Didn't like the thin slippery (cheap) wire of the led strips I was modding too much, still worked, but also might be my inept postman pat hands. Not in sale but wanted one for ages.
    Also: 1m Shakmods 2mm and 6mm white heatshrink and 5m of 4mm white sleeving. M3 anti-vibration standoffs, M3 dome nuts, washers, button head hex bolts AND the cheapest printer/scanner I could find on eBay, purely for the scanner. A bargain at £12.49 delivered.
    Not quite as much of a bargain as 3 Corsair SP120 RGB PRO fans for £6 from our very own @littlepuppi. Very generous indeed. :clap:
    Yaka and adidan like this.
  13. mrlongbeard
    mrlongbeard Well-Known Member
    31 Jan 2010
  14. Dr. Coin
    Dr. Coin Active Member
    13 Sep 2013
    Watch out after a little bit the pads start to fall off, especial if you have little boys playing with the clamps.
  15. The_Crapman
    5 Dec 2011
    Big boys like playing with clamps too :worried: :eyebrow: :hehe:
  16. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    Level established... :p
    The_Crapman likes this.
  17. Dr. Coin
    13 Sep 2013
    Yes, but they tend not to have inexplicable urge to remove the pads every time they see the clamp. I have a half dozen or so and only three pads left, the other have disappeared into unknown corners and crevices of my house.
  18. Weekly_Estimate
    Weekly_Estimate Gives credit where its due
    1 Feb 2010
  19. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I always thought about this desk. But then I bought a desk from IKEA and started using the Glorious XXL mouse mat.
    How is the surface?
  20. ElThomsono
    ElThomsono Well-Known Member
    18 Mar 2005
    New mini bolt cutters, sides and pliers:
    The plan for 2020 is to be all Knipex, so far so good:
    I probably have ~30 pairs of pliers, cutters and grips, but that's the toolbox sorted and the rest can go into kits and the welding bench and the like.
    Note the comedy sized Cobra-XXL at the back :lol:
    Fingers66, adidan, legoman and 2 others like this.
