  1. Goatee
    Goatee Multimodder
    19 Apr 2015
    VLP Sodimm, so tiny (yet expensive!!)
  2. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Time for some Wii high jinks;
    Yaka likes this.
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    What do you need such tiny RAM for?
  4. Goatee
    Goatee Multimodder
    19 Apr 2015
    A tiny build!
    Modding a PS1 :)
    Bloody_Pete and adidan like this.
  5. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    They've arrived!
    [ZiiP] NaloaC, Yaka, adidan and 3 others like this.
  6. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Looks like a good set you've put together there, I had previously only seen Bahco files with perfectly utilitarian but soulless plastic handles.
  7. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    See, for a second I thought you were going hog wild with the Ps1 hardware.
    But now I think you're putting something in a PS1 chassis, because that's the far more reasonable version.
  8. Andersen
    Andersen Brain for hire
    25 Nov 2002
    Pulled the trigger and ordered a Zotac RTX 2080 Super
  9. Arboreal
    21 Jan 2011
    Of course! The SODIMM slots on the STX are vertical, desktop PC style as there's not enough room for them to lie flat Thin ITX style...
    Goatee likes this.
  10. Vault-Tec
    30 Aug 2015
    Totally willy envy.
    The_Crapman likes this.
  11. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    adidan and Vault-Tec like this.
  12. Vault-Tec
    30 Aug 2015
    Those brushes are awesome. I got a set forever ago, bloody great they are. I just need the blower :D
  13. MLyons
    3 Mar 2017
    Just used it on a keyboard and it was an enlightening experience.
    Vault-Tec likes this.
  14. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    One of these and some Kryonaut
    Assuming it comes in a timely manner I now have all the parts to build a new system, but still need some new data drives since my current ones are #cough# years old and should been replaced #ahem# ago. I think a box of M-Discs might be in my near future.
    Just as well since painting this afternoon reduced my machine to a slide show at 6000x3600.
    pilsner72, Yaka and Vault-Tec like this.
  15. The_Crapman
    5 Dec 2011
    Yeh I almost got some of them, but they didn't have all the files I wanted with those handles, definitely don't want different odd handles and was actually cheaper to get the faithful hardwood handles anyway. Just have to fit them and now and hope I can get them straight.
  16. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Got one on order from ocuk for £49 on special but not in stock but I can wait.
  17. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    So much doge hair...
    MLyons likes this.
  18. Guest-44638
    Guest-44638 Guest
    Very floof...
    MLyons likes this.
  19. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    A summary of the last couple of days leading up to today: ALL THE THINGS
    Through-hole resistor set
    Through hole ceramic cap set
    Another GBS-8200 upscaler (I killed the I2C pads on the last one)
    Flux paste
    Female 2.54mm pin headers
    Mixed 2.54mm pin header set with (probably garbage) crimps
    i5 4590
    Samsung mSATA SSD
    Intel 7265 AC WiFi/Bluetooth card
    8GB DDR3 1600 SODIMM
    Beard grooming stuff, because I'm starting to look very unkempt - oil, balm, moustache wax, wooden comb, scissors
    Beard soap, because regular shampoo is really bad for facial hair - ideally I need a proper beard shampoo & conditioner, but this will do for now, I've spent enough recently...
    EDIT: Forgot a couple!
    Arctic Freezer 11 LP
    128GB MicroSD, because it was £12 and SD cards are always handy, so... why not?
  20. Goatee
    Goatee Multimodder
    19 Apr 2015
    They is tiny!!
    Its means I should be able to fit a slim 120mm in the CD tray.
