  1. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Send it to Bethesda so they can do what's right and overdue with Fallout76.
  2. fix-the-spade
    fix-the-spade Well-Known Member
    4 Jul 2011
    Setting upa home network today has proved such an unexpected ballache that I've given up and bought Ace Combat 7: Deluxe edition on Steam...
    ... I may or may not already have it on Xbox...
  3. legoman
    legoman breaker of things
    28 Feb 2010
    MOT + four new tyres, fronts cracked rears worn wonky, either tracking of bushes to blame on the rear. See if the garage can see which looking at it.
  4. yuusou
    yuusou Well-Known Member
    5 Nov 2006
    A second hand one of these with a 2400G, 8GB RAM and a 1TB rust spinner (I think, not entirely sure).
    adidan, Yaka, Arboreal and 2 others like this.
  5. Arboreal
    21 Jan 2011
    Ryzen DeskMini, yay! Lovely bit of kit.
    I nearly bought an H310 board from a DeskMini a couple of weeks ago, but didn't as it was without the OEM SATA cables. I couldn't see an easy source for them.
    I did however buy a cheap Gen3 i3 NUC just to keep the SFF habit going :D
    Have fun with a small miracle!
  6. Dr. Coin
    Dr. Coin Well-Known Member
    13 Sep 2013
    I first thought it was a PSU then I noticed the big IC in the middle and thought that seems a bit overkill for voltage regulation... then the penny doped.
    Arboreal and Goatee like this.
  7. Goatee
    Goatee Well-Known Member
    19 Apr 2015
    Been doing some research over the past couple of days and decided to treat myself to a new printer. Behold, the LD-002R! Catchy!
    I was comparing between the Elegoo Mars Pro and the Photon S when I spotted this on the Creality US store, stocked in the UK warehouse, delivery is next day via DPD.
    Given there is a $20 discount (and VAT seems to have been swallowed up by them) I managed to bag it for the US price which converts to ~£192. That’s the sort of price you can expect to pay from Banggood or AliExpress.
    The resin technology has come on too, with water based resins, so there is no longer a need for solvents in the cleaning process. So no more 95%+ IPA, for me it’s just warm water.
  8. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    But the rear IO...
  9. Bloody_Pete
    11 Aug 2008
    Do you have a link?
  10. Goatee
    19 Apr 2015
    Bloody_Pete likes this.
  11. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    Ordered. I've been after a 3D printer for *ages*, but the traditional filament-based ones are too bulky. That'll just about perch on the corner of my desk, if I shuffle things around a bit. Ta!
    IanW and Goatee like this.
  12. Bloody_Pete
    11 Aug 2008
  13. Goatee
    19 Apr 2015
    After my research (anti-vax level only, i.e. watching YouTube videos / reading reviews) my first stab will be using this:
    https://www.amazon.co.uk/gp/aw/d/B08251P8DP
    reviews indicate no difference in print quality.
    Price is 10-20% higher, but once you factor is your cleaning cost are water (free) rather than IPA / cleaner it might actually work out cheaper in the long run.
  14. Gareth Halfacree
    4 Dec 2007
    I feel like if your software uses WINE, claiming to support Linux is a bit of a cheat...
    But it does, at least, work. Looks pretty straightforward, too, which is good 'cos I'm only simple, me.
    Yaka, IanW and Goatee like this.
  15. Goatee
    19 Apr 2015
    I have a filament i3 Clone printer, but the “plug and play” nature of this is rather appealing. My filament printer needed a lot of “tweaking” and modding to get a decent print quality.
    There are some caveats with Resin, currently print volume is significantly smaller (120x65x160 vs 200x200x180 - WxDxH), your trading heat risks (bed and extruded) for chemical risks (resin) but print quality is better with resin but post processing and curing is required.
  16. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    Am i reading those dimensions correctly, and that you have a height of 120mm, depth of 65mm (front to back of machine) and width of 160mm (across the machine)?
  17. Gareth Halfacree
    4 Dec 2007
    I believe it's 120mm width, 65mm depth, and 160mm height - but aye, those are the overall printable dimensions. 's only for small stuff!
    MadGinga and Goatee like this.
  18. Goatee
    19 Apr 2015
    Yep Gareth is correct, its quite a bit smaller as it uses a 2k LCD to give the print at each slice. The current use cases are more for printing higher detail smaller objects, miniatures, jewellery, models. However the the new Saturn printer (currently on preorder) due for commercial release later in the year is supposed to have a 4k panel, which gets a print volume comparable to filament printers. Expect something in the region of £400-£500, so the next price bracket up.
    Its quite interesting the difference between the technologies, as my understanding with these printers is the volume of material is not really linked to print time, like on conventional filament printers. If you wanted to print a large flat panel 1mm thick on a filament printer it would take some time as the print head goes back and forth laying the print down all the material on a layer. On a resin printer the layers are "printed" at once and take a number of seconds / layer. This is relatively independent of if you print a small 10mm x 10mm part of a layer or the full build plate.
    Maybe I should retract the anti-vax comment above, I appear to know more than I thought.... :D
    MadGinga likes this.
  19. MadGinga
    19 Mar 2009
    Cool, ta.
    Pet peeve is dimensions without indication of which dimension is which...
    Interesting that the "depth" is very small, but can print quite wide (relatively)...
  20. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Damn you all, that printer looks rather tasty.
