  1. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    It's a big boy as well! Cleared a little space, looking forward to seeing it take pride of place in my current generation AV setup! :grin:
    Still waiting for confirmation on despatch. Have a feeling it might be weeks instead of days away. Which is a pity as my console gaming has gone on hold until I get the Series X. Although I do still need to finish off Ori and the Blind Forest. Final Swan song for the XBOX ONE X I suppose!
  2. Yaka
    Yaka Modder
    26 Jun 2005
    i just hope both sony and ms have done a better job cooling over long term this time round. i have found ps4/pro and xbone/scorpio to get louder an louder as time goes by. no amount of cleaning the dust out fixes it for either
  3. stephen0205
    stephen0205 Minimodder
    11 Mar 2016
    Mr_Mistoffelees likes this.
  4. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    Nixie tube clock :thumb:
  5. Byron C
    12 Apr 2002
    Elgato HD60 S.
    The capture card I should have bought in the first place.
    IanW, Vault-Tec and Arboreal like this.
  6. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Bought me a it dustbuster for my pc as a prezzie from my daughters for my birthday.
    Yaka and MLyons like this.
  7. Weekly_Estimate
    Weekly_Estimate Gives credit where its due
    1 Feb 2010
    Assassin's Creed Valhalla
    MSI NVIDIA GeForce RTX 3070 Gaming X TRIO
    LennyRhys, Spraduke and Byron C like this.
  8. BeauchN
    BeauchN Modder
    5 Apr 2011
    perplekks45 likes this.
  9. yuusou
    yuusou Multimodder
    5 Nov 2006
    Once you yourself recognise you've got a problem, it's too late.
    BeauchN likes this.
  10. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    You need to join the CKSSA (compulsive key switch swappers anonymous).
  11. BeauchN
    BeauchN Modder
    5 Apr 2011
    :) I’m hoping I’ll settle on one of them, or possibly two. The Pandas feel really nice to type on stock, but are a bit noisy, I’ll see what they’re like once lubed though. The Zilents have a nice tactile bump and are pretty quiet. But I’ve heard good things about the Alpacas and fancy trying a linear switch again
  12. Vault-Tec
    30 Aug 2015
    Looked at the posh brands. About £5 per meter. Looked at RF, £1.75 a meter.
  13. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I'm a fan of the Glorious stuff, have the Model O and GMMK here, fiancée's using the Model O-. Also, anything with a panda in the name or on the packaging is awesome.
  14. BeauchN
    BeauchN Modder
    5 Apr 2011
    How do you find the GMMK? I was tempted to pick up the compact, but then decided to build my own 60%
  15. Mr_Mistoffelees
    26 Aug 2014
  16. Vault-Tec
    30 Aug 2015
    I've got Van Damme now. IIRC it was a fiver a meter. Problem is one side is too short. It wasn't made up to be where it will be now.
    Yeah, quite familiar with expensive wires. Rogers used to do a 99% silver cable. IIRC it was about £500 a meter. Was part of the Crystal Link series that we never got to release because the new Japanese owners closed us down after 3 months of ownership.
  17. perplekks45
    9 May 2004
    I love it. The only issue I can see down the road is the use of a micro USB port instead of a USB-C one.
    I do however think the Ducky One 2 Mini I bought for my fiancée might be slightly better. Both have been good build quality, assembly was a breeze on both, they've been faultless in daily use. But the Ducky feels that tiny bit sturdier, heftier, ... better, for lack of a better word. Maybe this grass is greener on the other side speaking, but it's more than just the USB-C port on her keyboard that makes me think it might be just a fraction better.
    I'm tempted to build my own, but prices are sharing me away, to be honest.
  18. BeauchN
    BeauchN Modder
    5 Apr 2011
    I think, looking at Glorious’ website, they’ve refreshed the GMMK to use a USB-C port now. But if you pick one up from a reseller I guess it’s pot luck as to which you’ll get.
    Ducky boards are well made, I’ve got a Shine 3 TKL from years ago that is just solid. I was very tempted by the Mecha mini because of the aluminium case, but finding one in stock somewhere is a nightmare.
    Building one can get expensive, especially if you keep needing to pick up parts from different places because not everyone has everything in stock. But I figured it would give me a bit of a project and I’ve gone hot-swap so I can test out different switches fairly easily. Once I settle down on what I like I might go for a higher-end build, but I don’t think that will be for a while.
  19. David
    7 Apr 2009
    Decided to replace my 2tb portable drive with an SSD, but I already had a spare 2TB SSD so I just ordered a rugged case.
    and...
    ...because they were gurt cheap.
    Arboreal likes this.
  20. Arboreal
    21 Jan 2011
    A fine 'ruffty tuffty' looking case to protect all those delicate moving parts in your SSD.
    What did the 1TBs come in at?
    David likes this.
