  1. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    How's this? Overlaid water temp in green and added a new bar.
    Bloody_Pete and Goatee like this.
  2. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    Seagate IronWolf 6TB, 'cos one of the old shucked 2TBs in my old server is dying and I haven't fully retired the thing yet. Figured I'd splash out on a 6TB rather than another 2TB 'cos when I do retire the old server I can use it in the new server - I've still got two drive bays free.
    goldstar0011 likes this.
  3. jinq-sea
    15 Oct 2012
    @BennieboyUK Love that. Is it using an actual Pi too, or just the display?
  4. Vault-Tec
    30 Aug 2015
    Mine uses just the display. I have one I bought from Byron in the floor of my area 51.
    Byron C and BennieboyUK like this.
  5. sandys
    sandys Multimodder
    26 Mar 2006
    that looks so tidy compared to mine, going to have to rip it off :D
  6. BennieboyUK
    24 Nov 2010
    Thanks for all the feedback! I am happy to share my template file if anyone wants to use it? You can just adjust you your displays resolution.
    sandys likes this.
  7. BennieboyUK
    24 Nov 2010
    Just the display. HDMI to then gfx card and usb power to internal header.
  8. sandys
    sandys Multimodder
    26 Mar 2006
    That would be cool if you don't mind, I'd use it as a starting point, takes so long to position stuff with Aida
  9. jinq-sea
    15 Oct 2012
    I like it a lot. I’ve got a Pi screen sitting on the shelf
  10. BennieboyUK
    24 Nov 2010
  11. sandys
    sandys Multimodder
    26 Mar 2006
  12. Vault-Tec
    30 Aug 2015
    BTW if that is a touch screen pi screen don't connect up the USB touch screen. Windows didn't like it. I disconnected the data lines in mine so it just gets power. I mainly run animated videos on repeat on mine. Or I just drag Aquasuite onto it. I did use AIDA, but I found it was a proper time sink lol.
  13. Vault-Tec
    30 Aug 2015
    My forever speakers.
  14. sandys
    sandys Multimodder
    26 Mar 2006
    I've got touch enabled on my little second screen, works a treat in windows, I was surprised, you can even independently touch type and browse/whatsapp on second screen whilst playing games on the main screen without interruption, I didn't think that would work.
  15. Vault-Tec
    30 Aug 2015
    Mine crashed. That said, that was probably Windows 8 back then. I used it as a test screen for PCs for a while before actually putting it to a use. It was well handy for that.
  16. legoman
    legoman breaker of things
    28 Feb 2010
    S7 Tab 256Gb model via work so a chunk less than retail. I'll order some case for it as well
    Replacing my iPad mini 2 which has a random battery life of between 8 and 48 hours. Will do pretty much everything I need so office apps, media consumption an design work. The S Pen should be fun to get used to.
    Also means I can plug it into the PC as a second monitor as needed which will be handy for lots of things.
    Arboreal likes this.
  17. Mister_Tad
    27 Dec 2002
    An apparently very special nylon strap and plastic clip just arrived in the post today.
    The pull strap for the roll cover on my truck, or rather the plastic clip that activates the latch broke a couple months ago. Upon inspection I thought "well of course that plastic clip was going to break given the force that's put on it pulling the roll cover to and fro, I'll bet a third party makes one with a brass or steel clip so it doesn't happen in another year"
    Nope.
    Nevermind, I'm sure you can just get the plastic bit for a few quid.
    Nope.
    £53. 1.9m nylon strap, aluminium carabiner, and aforementioned plastic clip that's absolutely going to break again.
    Much resent.
  18. Shirty
    18 Apr 1982
    I feel your pain. Bought a new rubber strap for my Breitling the other day. Recycled the deployment clasp from the damaged strap so we're literally talking about 2 x 8cm long moulded rubber straps, nothing fancy. £60.
    Madness. I hate OEM part prices sometimes, unless there is some tangible added value.
    Mind you , if I'd wanted a new deployment clasp at the same time the bill would have been £300-£850 depending on the finish. On a part with a BOM cost of no more than maybe 20 Swiss Francs.
    perplekks45 likes this.
  19. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Sounds like a convoluted reason to get into 3D printing metal.
    I hear those laser machines that print titanium are rather nifty.
  20. Mister_Tad
    27 Dec 2002
    Since this will definitely break again in the exact same way, it would theoretically be the cheaper option I kept the truck for long enough.
