  1. Gareth Halfacree
    4 Dec 2007
    It's more than a scanline filter: it's a GLSL shader, and does subpixels and geometry shifting - so the image literally curves.
    Here's an uncropped - so 1920x1200, exactly what I see on my monitor - shot of Windows for Workgroups in the same shader (heavily JPEG compressed to get around forum upload limits):
    You can see the curve along the sides and top, if you look closely. This one's pretty subtle - there are shaders that look like a 7".
    And here's the subpixel simulation:
    You can see it's not scanlines, it's a literal attempt to simulate what a CRT looks like close-up.
    That particular shader is a tweaked version of CRT-Lottes. There's a whole bunch here to play with, if you fancy giving 'em a go yourself. I swear by 'em!
    Dr. Coin likes this.
  2. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    Much obliged! Will definitely dig into shaders in more detail when/if I use other emulators... I was never much of a DOS person so I don't have much need for DOSBox, but I do use other emulators from time to time.
  3. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Picked up one of these from B&Q. Wanted the same thing from Ikea but they aren't in stock.
  4. Pete J
    Pete J Employed scum
    28 Sep 2009
    I think I've accidentally started collecting comic books.
    perplekks45 likes this.
  5. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Harleen is quite good.
    Battle Pope is also quite the giggle
    Sunstone is a little risqué, but also would recommend.
    Pete J likes this.
  6. Byron C
    12 Apr 2002
    The ol' card got a bit of a workout this morning...
    LG NANO86 65" TV
    Ryzen 7 3700X
    Corsair Vengeance RGB 3600MHz 16GB
    500GB Samsung 970 Evo NVMe
    (I already have a 1TB SATA SSD, so the NVMe will be fine for a boot drive)
    Corsair CX750F Fully Modular PSU
    Oh, and a partridge in a pear tree braided SATA cable... because, at this point, why the f- not
    Vault-Tec, Arboreal and adidan like this.
  7. Arboreal
    21 Jan 2011
    Good SSD combo @Byron C. I'm booting from 500GB NVME and Data on 1TB M.2, which means a lot fewer cables!
    Byron C likes this.
  8. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    A box of meat
  9. MightyBenihana
    MightyBenihana Colour my life with the chaos of trouble
    8 Sep 2011
    When you get that TV Byron, could you let me know what you think. I am on the fence between a 65" and 75". I will be sitting about 3 metres back. I have a few weeks yet as I am buying a house.
    Byron C likes this.
  10. Byron C
    12 Apr 2002
    Willdo. TBH it's going to be so much better than my nearly 10 year-old 1080P TV that I'm almost certainly going to be blown away by it, regardless of whether it's objectively a 'good' TV or not.
    If it helps you make up your mind then I found these two links give good 'rule of thumb' advice if you want to really get the best viewing experience:
    https://myhometheater.homestead.com/viewingdistancecalculator.html
    https://www.rtings.com/tv/reviews/by-size/size-to-distance-relationship
    The second is basically a more simplified version of the first. Both are based on guidelines from the Society of Motion Picture & Television Engineers (SMPTE) and THX on viewing angles in cinemas. You're about the same distance from the TV that I am - about 10 feet - and for a 65" screen you're at the max limit for the THX spec and too far back for the SMPTE spec:
    75" at that distance however is inside both THX and SMPTE maximum viewing distance:
    Of course you might not really care about having 'a cinematic viewing experience' and every person/home will be different, so this might be meaningless for you :). When I measured up screen sizes, I quickly realised that 75" would be absolute overkill - it would just look comically large in my lounge... 65" was the absolute max size I settled on, THX/SMPTE guidelines be damned :grin:.
    MightyBenihana likes this.
  11. mrlongbeard
    31 Jan 2010
    A new sat nag for the bike, the old TomTom was 5 years old and had been down the road too.
  12. Mister_Tad
    27 Dec 2002
    FWIW, I find 75" @3m a pretty good spot for a room that's all about TV.
    For anything else, I think as Byron suggests, it could be a bit much. TBH I find that tends to dominate even a large room, and 75 is 40% bigger again.
    So I think it comes down to whether you want it to dominate the room or not, rather than the right size to viewing distance.
    MightyBenihana and Byron C like this.
  13. Pete J
    28 Sep 2009
    Yup, looks like I'm becoming a comic book collector:
    goldstar0011 likes this.
  14. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I have a 65" Pana oled which is only around 8-9 feet from my seating position and I would say it's a good size for regular TV watching of 16:9 content but for 2.35:1 aspect ratio content I find it a little small so I'm probably going to upgrade to one of the new 77" 2021 oleds this year. So it depends what type of person you are, if you are bothered about the aesthetics of the room just get whichever best fits your space but if you are someone who wants more of a cinema experience with a decent level of immersion I would go for the 75"
  15. Byron C
    12 Apr 2002
    Wot he sed.
    This is what it currently looks like with a 40" TV (click to embiggen) - ignore those bookshelf speakers, they're not actually hooked up and I'll be moving them out of the way tomorrow.
    The measurements I've taken indicate that the 65" will fill the entire width of that Kallax unit - I'll take an 'after' photo tomorrow when I get chance.
  16. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Are you buying to read or to sell in the future?
  17. Pete J
    28 Sep 2009
    I never buy to sell. For my personal enjoyment!
  18. perplekks45
    9 May 2004
    Cool, what are you into then? Other than the bat, obviously.
  19. Mister_Tad
    27 Dec 2002
    A Hue Centris cross ceiling light for my office
    I've been shopping to replace the pretty pink lampshade and single bulb since we moved in, and kept coming back to this, and then kept going away from it for a few hundred reasons. Finally bit the bullet... a moment of pain for what's hopefully many years of use.
  20. jinq-sea
    15 Oct 2012
