  1. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    The removable tray was one of the main reasons why I had to have the 840 as a replacement. Unfortunately the 840 is a victim of modern production practices and not built quite as well as the 201 was, the tray is on simple Al runners rather than the very nice bearings that the 201 used and the smoothing of the cut edges inside has not been done anywhere near as well. I mean, it's not an early 2000s OEM level of hand shredding steel chassis, but not great.
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    6800XT for.. Reasons.
    Yes. Reasons. That covers it.
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Fingers crossed the DLSS-equivalent AMD will release on 22 June is good. Then you'll have a brilliant card instead of a very good one.
  4. liratheal
    20 Nov 2005
    One that works would be an excellent improvement! I'm currently PCI-riser cabling an RX550 out the side of the case to get display out. Seems all my fiddling and farting around has made the rather temperamental 5700XT go "No".
  5. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
  6. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    I got some perforated XL pads on my dt990 pro's they are so comfortable
  7. Andersen
    Andersen Brain for hire
    25 Nov 2002
    Preparing for Trans Pride on 26th
    Gonna pair well with my trans flag
    Byron C, liratheal and Bloody_Pete like this.
  8. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    It's here! :D
    The_Crapman, Pete J, David and 3 others like this.
  9. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I'll buy it off you for a grand :p
  10. LennyRhys
    LennyRhys Oink!
    16 May 2011
    With every day that passes, selling my GTX1080 for £260 makes me feel more dead inside. Why... W H YYYYY?
  11. David
    7 Apr 2009
    You ordered your thermal pads yet?
    BTW you can tell it's from Scan - the corner of my 3090 box was bashed too*. Considering the sheer quantity of bubble wrap you get when ordering an SSD or a few cables, I was appalled by the zero effort when shipping my £1400 3090 FE - they just chucked it in one corner of a box and filled the void with packing paper. Hence the bashed corner.
    * For the pedants: Yes, I know they are the annointed FE distributor in the UK
  12. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Perhaps because CEX gave me £315 for mine?
    Not yet. I want to see if they've fixed it this batch, as someone on LTT forum said.
    Mine was in a slightly larger box with several (but not enough!) strips of those air bags they use.
    I've thrown it into the PC, and my 3DMark Time Spy score has gone up from 7563 for the 1080, to 14878 for the 3080. :D
    LennyRhys, Bloody_Pete and David like this.
  13. David
    7 Apr 2009
    The newer pads are better - there was a marked difference between my 3090s - but I still changed out the pads on the new card and saw a decent improvement.
  14. perplekks45
    9 May 2004
    A UNICORN!!!
    goldstar0011, IanW, Pete J and 3 others like this.
  15. Almightyrastus
    21 Mar 2002
    A new EDC hank for the ol' pockets. Had to get the circuit board design at some point (electrical engineer and all that) and the microfibre backing is great for glasses cleaning. A fiend of mine makes these and sell them through Etsy.
  16. enbydee
    enbydee Minimodder
    10 Jul 2014
    A password rememberer, the kickstarter for which was plugged here a while ago now, arrived today.
    Byron C, Goatee, IanW and 1 other person like this.
  17. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    FTTP just became available on my street, so I've booked Sky (who I'm currently buying FTTC from) to come on June 28th, to switch me from 38mb to 145mb for an extra £7/month. :D
    UPDATE: Just had the confirmation email from Sky. They say the minimum speed to trigger their guarantee will now be 100mb/s!
    Also, this:-
    goldstar0011 and MadGinga like this.
  18. Goatee
    Goatee Multimodder
    19 Apr 2015
    mine arrived too.
  19. sandys
    sandys Multimodder
    26 Mar 2006
    That's similar to my bandwidth estimates from Sky, basically got 160/30 all day everyday with great latency, they've been a good ISP, I have just left for Virgin which could be my biggest mistake, Sky being so good but its far cheaper so we will see.
    IanW likes this.
  20. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Bigger printer for bigger 'things'
    Bazz, Arboreal, Pete J and 3 others like this.
