  1. veato
    veato I should be working
    15 Jan 2010
    Quest 3 512MB. Have wanted to upgrade from my Rift S for some time and bit due to the price drop.
    Vault-Tec likes this.
  2. Vault-Tec
    30 Aug 2015
    Well fug.
    I have been running Arctic slim fans in my server since day 0. They're crap. Mostly as they are flimsy, so like to catch the holes I cut. This did not happen with the thicker fans I had in there. I was due to replace both any way, but today when I tore the server down for upgrades I realised one was actually dead.
    I got two of those. They intake the air. The server runs for up to two weeks at a time, and clearly that was too long for cheap crappy fans to handle. I also decided whilst in there to do it properly so got one of these for the cooler.
    I was also extremely pissed when I realised that the 40mm fans I bought are 24v. FFS. It was less aggro to buy a buck booster for £8 and run them from that. It turns 12v into 24.
    Good news is it works very well. The 40mm fans were not noisy at all, but they include low noise adapters so now they are even less offensive.
  3. Vault-Tec
    30 Aug 2015
    Blimey. Looks like I literally caught this before I lost 1tb of music.
    Also. I am loathe to throw away my Huntsman Elite over some shiny key caps. Looks like Razer do Pudding caps now, so £29.
    Will be my spare board now.
  4. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    I think I'm addicted, I've put it in a salt shaker.
    @Vault-Tec this is all your fault y'know.
  5. David
    7 Apr 2009
    I might have accidentally a Lenovo P350 tiny. I might go full beast and grab a A4000 SFF and a LP custom cooler. If swmbo is in an accommodating mood.
    Currently pissed and in a floating nightclub, but that might be the best time to get her approval.
    She does like alcohol and a dance to bassy shite music.
  6. Vault-Tec
    30 Aug 2015
    It’s amazing isn’t it? Dang!
  7. Vault-Tec
    30 Aug 2015
    I’m tempted to try it on roasties. The yankees don’t do roasties so I’m wondering how it would be.
    They also do a new lemon one I must try too.
    Another of my habits picked up in the USA. Crab and old bay pizza. I used to get it at Ocean City NJ every time I went, which was a a lot.
  8. Mister_Tad
    27 Dec 2002
    Didn't manage to get a vanity PS5 pro (even though I would have actually used it and not scalped it), but did grab a minor consolation prize this morning when the preorders popped.
  9. The_Crapman
    5 Dec 2011
    I've used the normal one on potatoes wedges in the air fryer and they were great. There's a spicy one too, Mrs Crap used that one a cod, leek & potato tray bake and it was so good. Sounds really weird but really worked.
    Bought 2 dehumidifiers. A little one to go in the hole under the stairs to keep the damp in check
    electriQ 5L Quiet Compact Compressor Dehumidifier
    Tiny thing that'd fit any cabin luggage size restrictions, but has all the features; hepa filter, charcoal filter and ionisor to try and keep the musty smell in check.
    We've got a dimplex 10L/day one we borrowed from my mum and age ago she wants back, that normally fills it's bucket by morning run periodically through the day and overnight. I had both running simultaneously and both filled their tank in about 16hours. I had planed on getting a Meaco Arete Two 12L to replace the borrowed dimplex, but is out of stock everywhere and if both 10L and 5L a day can have their full thought better get a higher rated one:
    electriQ 20L Low-Energy Smart Wifi Laundry Dehumidifier
    Has all the bells and whistles and should be a darn sight quieter than the dimplex
  10. kenco_uk
    28 Nov 2003
    Another PSVR2 as the first one I bought used and expected signs of wear, but it looked in pretty good nick, apart from the lead from the headset to the PS5 looked like it had been used as a skipping rope. Unfortunately though, the display in the headset kept glitching out, like a black screen with a line of white static every few minutes. It didn't help that when it arrived, it was all squashed into a box with little to no padding. Deary me. So that one's going back and a new one is on its way. When it was kinda working, despite glitching, my goodness, the sheer clarity - particularly Kayak VR - is really impressive. I hadn't got as far as using the pcvr adapter as I didn't want any 'big' experiences to be marred by the glitching.
    Also, I found my old Nikon 18-55 kit lens while doing a lot of sorting through stuff over the past couple of weeks, so part-exchanged for a Fuji telephoto lens through MPB.
  11. Vault-Tec
    30 Aug 2015
    Pizza stone. I assume you need to pre heat the oven with it in yes? so it is hot when you put said pizza on it?
  12. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    Yep. Check the instructions that come with it, it should tell you how long to pre-heat it for. I pre-heat mine at full whack for a minimum of 1 hour before use.
    Also, they usually recommend against washing these things. The risk is that water gets into small cracks or pores, and if it doesn’t fully dry out it can risk the stone ‘exploding’ in the oven when you heat it. Just scrape off any errant cheese, toppings, etc, and the pre-heating should be more than enough to kill off bacteria and other nasty shizz.
  13. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    ...knowing nothing about these, an hour seems excessive?
  14. Byron C
    12 Apr 2002
    That’s what the instructions with mine recommended. It’s a solid ol’ lump, got to be at least half an inch thick, maybe more.
    It’s a rather large thermal mass, but you want it as hot as you can possibly get it. A traditional pizza oven is north of 300 C, and most domestic ovens probably top out around 250. A nice big thermal mass that’s piping hot - and stays piping hot - helps keep the temperatures up and helps cook pizza bases better.
    Just make sure you give it a couple of hours to cool off when you’re done :grin:
  15. ElThomsono
    18 Mar 2005
    Ah right, I was expecting more like 5mm; does it make a welcome difference on a cheap pizza?
  16. Vault-Tec
    30 Aug 2015
    Awesome thanks. I don't intend to wash it. If anything gets stuck on it I will just scrape it off. I won't heat it for an hour, though. Will just preheat the oven to temp then put pizza in. I am a little concerned as I cook at night when the sleep meds are just kicking in, so I need to be careful at least a bit.
  17. Vault-Tec
    30 Aug 2015
    Just made a great discovery. I thought I had used all of the slots on my server board. Well, desktop board I use in the server. I realised I have a free x1 slot. Result ! I only want a 2.5gb card in the server and the desktop I use to send data onto it. Everything else is read only stream. So I got two Intel based cards, as TrueNAS doesn't like the Realtek based ones.
    And a switch. Again, no point going ham as only two things will use it.
  18. Vault-Tec
    30 Aug 2015
    Looks like I will need a new router too. That can wait for now. I'm away for two weeks from tomorrow so yeah.
  19. Byron C
    12 Apr 2002
    For pre-made frozen or chilled pizzas… probably not. I don’t think I’ve ever tried it tbh…
    But if you’re making it from dough then it definitely does make a difference. It’s not as good as a pizza oven, but it’s a hell of a lot easier to store and a hell of a lot cheaper than a pizza oven.
    I’d love to get a proper pizza oven but I can’t justify the cost, I’d use it a few times a year at most.
    Arboreal likes this.
  20. veato
    15 Jan 2010
    I had a stone for a while but it did eventually break. I used to wipe it down (not soak it) and always let it heat up and cool down inside the oven. A pizza peel was essential too.
    I now use a cast iron shallow/pancake pan. Get the pan hot on the hob and the grill on max. Drop on the dough in the pan on the hob and when it starts to puff up a bit add sauce and toppings then stick it under the grill. This was in a Franco Manca cook book for those lacking a pizza oven.
    The_Crapman likes this.
