  1. Vault-Tec
    30 Aug 2015
    I cook frozen ones. I had a ventilated pan and it is a bit dead after all the years of use so I figured I would get a stone. The base never crisps in the pan I have. Will be interested to see the difference. It didn't cost any more than a new pan so I figured it is worth a try :)
    Byron C likes this.
  2. sandys
    sandys Multimodder
    26 Mar 2006
    If you have a self cleaning oven you can use that to get temps beyond 250C perhaps up to 450C, lovely for Neapolitan pizza base.
    Somehow I have ended up with a few Pizza ovens......how does that happen, indoor / outdoor, whenever, always Pizza all the time in my house :D
  3. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    After getting the IFS kit (£4100) fitted to my F100, I've now found I need a new sump for the engine to get the engine to clear the steering rack (£1k) so
    Rear well sump
    oil pickup pipe
    cap bolt with mount for pickup pipe
    dipstick
    sump gasket
    high volume oil pump
    Universal Joint for the steering rack
    and a baseball cap, :D
    £715 shipped from Summit in the US, + whatever import charges get stuck on it too, probably not going to have much change left from £1k.
    Then once the engine fits without hitting anything I've got to make some engine mounts, then I've got to modify the drivers exhaust manifold so I can connect the steering column to the rack. Oh fun, :D
    This trucks going to bankrupt me :grin::grin::waah:
    Yaka likes this.
  4. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    You won't like to know what I just spent on my GT then....
    Cerberus90 likes this.
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  6. Mr_Mistoffelees
    26 Aug 2014
    Yaka and IanW like this.
  7. Vault-Tec
    30 Aug 2015
    That weed I bought with the CBD on is awful.... To smoke. It's so harsh it just kills your throat. Probably because of all of the CBD on it. As thus I need to get some coconut milk next time I do Iceland and make tea with it. I have been waiting for two months for this to come up.
    An oz of hash. Which I prefer 100 times more than the weed. Just a quick bong is enough to set me up.
    Almightyrastus likes this.
  8. TheBlackSwordsMan
    TheBlackSwordsMan Over the Hills and Far Away
    16 Aug 2009
    I snagged this old battered e-bike with a battery for a 20$ donation to the SPCA. It needs a bit of TLC and possibly a new controller but it’s solid and the motor works. Also, against all odds, the bloody battery is alive. With a full charge, at max speed & without pedaling, I got 21.8km on flat surface. I couldn’t believe it, I was expecting either dead or drained after 1km.
    perplekks45, IanW, Yaka and 5 others like this.
  9. Gareth Halfacree
    4 Dec 2007
    A software update bricked my Motorola Edge 40 Neo this morning, and while I've dug an old handset out to keep me going it's not great: 64GB storage, last security update 1st of May... 2023.
    There's a saying, they have it in Texas, fool me once, shame on you, fool me twice, won't get fooled again:
    Yes, I've bought another Motorola. The Edge 50 Neo, this time, which I'm sure will be much more reliable(!)
    To be fair, I've sent the Edge 40 Neo in for repair/replacement/refund via Amazon, which was easy enough - but it's a 14-day turnaround, and I spend... like, a third of the day working on my phone. Hopefully they say it's buggered and can't be replaced, so I get a straight refund; if not... does anyone want to buy a Motorola Edge 40 Neo?
  10. The_Crapman
    5 Dec 2011
    If you're just doing frozen pizzas don't use a tray and you'll get a crisp base. If you want to prevent topping dripping off onto the oven base, put a tray on the rack under it.
    You can also get "pizza steels" which are supposedly better than pizza stones for domestic oven use. Heat up quicker and get hotter for a crisper base, but a large well seasoned cast iron pan just as good and will do deep pan/Chicago style pizzas thanks to the cupped edges.
    Vault-Tec likes this.
  11. The_Crapman
    5 Dec 2011
    Potentially yeh. Mrs crap is currently running my old pixel 6, but she managed to break the screen within days, the usb port is buggered and battery is a bit sketchy. Although the battery is perhaps more of her own doing as she has no regards for selective notifications.
  12. Vault-Tec
    30 Aug 2015
    Reason I never put them on the rack is because they have literally sagged between the bars in the past and made the worst mess. Ever.
    The stone has handles on, so I just realised I really should have these too.
    Will be using it for the first time next week. Away atm.
  13. The_Crapman
    5 Dec 2011
    Really glad I went with the 20L model. Whilst a proper comparison would be a lower rated of the same line, this thing strips water out the air like no tomorrow. Fills the 5L tank in a day not even running max fan speed, no more condensation on the windows in the morning, still pulled a full tank out yesterday despite no one having a shower or cooking. Well worth it.
    adidan likes this.
  14. adidan
    25 Mar 2009
    I have a couple of Meaco DD8Ls, the one in the loft room did a great job stripping condensation that would layer the veluxs in the morning. Barely had to run much, emptied about once a week.
    The one downstairs would be on pretty often in comparison and emptied daily but it had two rooms, a downstairs toilet and kitchen to deal with.
    Now we've sold up and currently in a rental I don't actually need them, humidity is bang on and no condensation. They're on standby when winter it's and they may be needed when we buy.
    Dehumidifiers make such a difference to just day to day life though.
  15. The_Crapman
    5 Dec 2011
    CHERRY KC 200 MX MX2A SILENT RED Switches, Bronze/Black
    Bored of current board, fingers still battered for demolishing the lounge, so wanted something with lighter switches and will be interesting to try out the new MX2A switches. Board looks real nice and already got a set of caps that'd look great on it.
    Yaka likes this.
  16. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
  17. Mister_Tad
    27 Dec 2002
    My first mechanical keyboard... its probably a bit pedestrian compared to more esoteric options, but I love/need the the quick-buttons to switch devices in a jiffy
    And two desk mats bundled at no cost for some reason? I'm not complaining.
    Pete J and Yaka like this.
  18. David
    7 Apr 2009
    The quick switch buttons are why I still love the MX Keys keyboard
    Mister_Tad likes this.
  19. The_Crapman
    5 Dec 2011
    Absolutely no idea where the caps are I was gonna use. Might have sold them or already used them in a board for someone else. Found a set similar, but actually prefer these (other one had grey not black function keys) and £20 delivered
  20. sandys
    sandys Multimodder
    26 Mar 2006
    Been getting a bit annoying with my Honor phones Desktop experience, too many glitches I have to work around, it is something I use most days and have done for years in conjunction with a portable screen, was always near perfect on Samsung as they can do functional software better than most, no other phone I have tried comes close.
    So thought it was time to drop my Honor Magic and pick up a Fold again, but the Fold hardware is so grim compared to what I have, big and heavy, so I have gone down the tablet route, this is new for me, not sure I can make it work the way I want but we will see.
    So purchased the 14.6” Tab S10 Ultra, seemed a good deal, same size as my portable screen but should have a properly functional desktop experience again as it is Samsung, seemed a reasonable deal with pen and Keyboard for less than 1k.
    If it is good perhaps it may even supplant my laptop as a travel device, though my 16” laptop is 300 grams lighter than the 14.6” tablet and it's add-ons to make a laptop :eek: how does that happen :D
