  1. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    lancer778544 and stephen0205 like this.
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  3. Gareth Halfacree
    4 Dec 2007
    It am arrive! Unsurprisingly, it's rollers and encoders so SUPER NOISY and slow. More surprisingly is that those aren't left, middle, and right buttons; they're left, hold-left, and right. The hold-left button acts like you've held down the left mouse button, so that you can drag-and-drop without having to actually hold it down.
    That's great for accessibility, but... I was going to use this with an Acorn Archimedes emulator. There's a lot of middle-clicking on an Archimedes... Hmm.
    IanW likes this.
  4. RedFlames
    23 Apr 2009
    Ponder the orb... ponder the orb!
    Gareth Halfacree likes this.
  5. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    @David @stephen0205
    Here you go both, just installed the PTM7950 now. Not the easiest to work with but thats only really down to trying to get the plastic sheets off it. It was in the fridge for about 25 mins before I applied it.
    100% power target, 21 degrees ambient and "stealth" fans:
    and just for the hell of it, 119% power target, 22 degrees ambient and "stealth" fans:
    Really, really pleased with that, would highly recommend. I bought mine from here on ebay (not affiliated or anything). I hear its supposed to get better with a few heat cycles too so will keep an eye on things.
    David likes this.
  6. perplekks45
    9 May 2004
    In that article I linked, there is clear evidence of burn-in. Looks more than decent, that stuff.
    lancer778544 likes this.
  7. David
    7 Apr 2009
    That's a significant reduction - very nice.
  8. lancer778544
    5 Jan 2011
    Ah thanks perplekks, I just had a read now, good to know.
    perplekks45 likes this.
  9. stephen0205
    stephen0205 Mr Steve
    11 Mar 2016
    Wow, thats actually mental how well it looks like it works. I had a gander at buying it the other night, saw alot of people making comments about buying it but getting fake versions of it, which i thought was also mental. But well done man that is some result. Need to keep that in mind for a laptop :)
  10. Gareth Halfacree
    4 Dec 2007
    Took it to bits. Amazingly clean inside - doubt this thing's been used more than half an hour since manufacture. Gave my ball a rub (fnarr-fnarr) and rubbed a bit of grime off the rollers. It's got optical encoders, as expected - on the underside of a PCB which has been welded onto the plastics. Thanks, Traxsys. Hope they never need cleaning or replacement...
    What I didn't see, sadly, is a handy jumper or DIP switch or something which turns the hold-left button into a middle button. Worse, the buttons are marked on the PCB as "SWL," "SWR," and "SWM" - meaning it is a middle button, it's just that the firmware's programmed for left-hold instead. Not something I can fix, that!
    No chance of remapping it in software, either, as it doesn't show as a distinct button:
    Code:
        state 0x2000, button 1, same_screen YES
        state 0x2100, button 1, same_screen YES
    The first transition is pushing and releasing the real left button, the second is pressing the middle button twice - it shows up as if I'd pressed and held the left button then let it go. Boo-urns!
    EDIT:
    Oh, and the reason it's so noisy is 'cos there's knack-all in that plastic case - the wrist-rest bit is entirely hollow. Stick a bunch of foam in there and it'd be a lot quieter, I reckon.
  11. perplekks45
    9 May 2004
    Our lowball bid for the upgrade of our flight tickets to Copenhagen were accepted.
    Even though the Air France lounge in Frankfurt's terminal 2 is definitely nothing to write home about, free food & drinks as well as being away from the unwashed masses was worth the extra bit of money.
    Now, I'll dare trying the wine selection. The quality of everything else in here is mediocre at best, but there's at least one bottle of wine that looks decent. Fingers crossed...
    Almightyrastus and IanW like this.
  12. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Bought this for something very special that I'll probably have a few months to wait for.
    WireView pro reverse, come with a sensor that you place between the gpu wires to keep a eye on temps.
  13. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    A dozen of Belgium's finest, dry January was a long old month.
  14. yuusou
    yuusou Multimodder
    5 Nov 2006
    It was dry January?! I completely missed it! I'll try again next year.
  15. Mr_Mistoffelees
    26 Aug 2014
    Dry January means nothing to me, hardly drink alcohol at all now. Never set out to stop alcohol, just slowly drifted away from it over the last 30 years.
    blackerthanblack, IanW and adidan like this.
  16. ElThomsono
    18 Mar 2005
    I'll send you a reminder on the first of February.
    yuusou likes this.
  17. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Same, but only since the plague times. No-one to drinkies with meant no need for drinkies.
    Mr_Mistoffelees likes this.
  18. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Don't drink myself any more just save for that new tech smells :thumb:
    IanW and Mr_Mistoffelees like this.
  19. Andersen
    Andersen Morally despicable and ethically objectionable
    25 Nov 2002
    Technically a purchase: new broadband, Community Fibre 1/1Gbps
    Byron C, IanW and yuusou like this.
  20. yuusou
    yuusou Multimodder
    5 Nov 2006
    A last breath of air for my aging laptop:
    Nvidia GTX1070M 8G (should work fine with the custom bios I got before the dev got hired by Eurocom)
    New battery, should be enough to last a whole 1h30m
    Yucun 1TB mSATA SSD (amazon special)
    stephen0205 likes this.
