  1. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    My Android Auto wireless dongle (a venerable Carlinkit A2A) entered the next phase of existence over the weekend.
    IIRC, it cost ~£60-80 in 2020, with no updates available since 2022. Figured I got my money's worth.
    Then on the daily deals page of the rainforest, this popped up for £15:-
    Don't let the size of the pic fool you. It's only about 20mm square x 10mm thick (USB plugs for scale)
    Seems to be a lot faster to boot than the Carlinkit, too!
  2. Andersen
    Andersen Morally despicable and ethically objectionable
    25 Nov 2002
    Another monitor arm, Project Yeet Them Stands goes on
    Dinky USB 2.0 extension so I can have mobile broadband as backup for main connection
  3. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Feels good to have this back, a few days of using a corded mouse on a mat, shudder.
    The_Crapman likes this.
  4. Mr_Mistoffelees
    26 Aug 2014
    Gareth, Nice But Dim!
    Pete J and Gareth Halfacree like this.
  5. Gareth Halfacree
    4 Dec 2007
    Received and installed. Motherboard (Asus B450M-K Prime) reports one "DOCP" profile, which is what Asus calls XMP. The profile shows the right timings and voltage and is close enough to the claimed 3,600MHz - 3,596MHz or something like that, I forget.
    But when I pick it... it sets the speed to 3,200MHz. Yeah, no idea why. Tried setting it to 3,600MHz manually: instant POST fail. Tried the next step down, POSTed but wouldn't boot. Got it at 3,400MHz now and just finished a 32GB memtest loop in the background while doing some real-world stuff, no crashes or errors. And, yeah, it's faster than the 3,200MHz stuff I just removed, and the difference between 3,400MHz and 3,600MHz in real-world usage is basically zip, but... annoying.
    Mind you, the motherboard's not exactly new and I'm driving it from a notoriously RAM-sensitive second-gen Ryzen 2700X, so there's that. Might be able to clock it higher if I updated the CPU - the board says it'll take a 5950X on the latest (five-year-old) BIOS - but maybe it's time to start saving up and consider a move to AM5 and 128GB of DDR5...
  6. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I'm fairly sure someone on here had similar woes with a 4-stick Ryzen setup - might have been @Pete J ? I think the conclusion was 2 sticks good, 4 sticks bad for Ryzen and DOCP/XMP.
    Pete J likes this.
  7. Gareth Halfacree
    4 Dec 2007
    This *is* a two-stick set - my board's only got two slots!
    Arboreal and Pete J like this.
  8. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Oh, apologies, thought you'd doubled up with a second pair :D
  9. Gareth Halfacree
    4 Dec 2007
    Nah, I had 32GB of 3200MHz (which, come to think of it, I might have been running at 3,000MHz) and took it out to go to 64GB.
    Had a brief look at PC Part Picker: for £850-ish I could get a new motherboard, Ryzen 9 9900X (50% more cores, several generations newer than my 2700X), cooler, and 128GB(!) of DDR5. Tempting, very tempting, but I can ill-afford downtime building it up. Probably better just sticking a 5950X in my current board, which would be a vast improvement *and* has 16 cores (so might actually be *faster* for my workloads than the 12-core 9900X...)
  10. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    Android Auto... wireless... dongle...?
    [interest piqued]
    [interest piquing intensifies]
    Bum, no bueno for my 2013 shitbox then... At least the car supports the iPod protocol - I'm amazed there's still native support for that in iOS. Plug it in, car sees iPod, phone pipes audio over USB, and I get to be distracted by the vast array of media content available via my phone.
  11. sandys
    sandys Multimodder
    26 Mar 2006
    a 12 core 9900x might be that much faster that 16 cores of 5950 can't keep up anyway :(
    Always surprises me how much Zen got better each generation, my handheld has 4 proper zen5 and 8 Zen5e and it runs rings around my 5950, whilst multicore is better in stuff on 5950, you are looking at 16 full cores using 4x the power vs a handheld efficiency cores that back clock down 60%ish because they only have 20w to play with.
    A 12 core full desktop zen5 should be a beast.
    Just geekbench 6 on my CPUs 5950 (16/32 pretty well tuned ) vs non tuned play things zen4 mobile (8/16) and zen5 zen5c (4 + 8 )
    Idioteque and Gareth Halfacree like this.
  12. yuusou
    yuusou Multimodder
    5 Nov 2006
    Most mult-core benchmarks I looked at (was brief, mind) show the 9900X to be at least 17% faster than the 5950X. Older Ryzens (Zen and Zen+ in particular) had pretty weak memory controllers. Zen 2 and Zen 3 were better, I've got 2x32GB 3600MHz on a Ryzen 9 3900 (non X) and it's happy. A BIOS update may help, but no guarantees.
    Gareth Halfacree likes this.
  13. Gareth Halfacree
    4 Dec 2007
    Oh, it's nuts - I bought a laptop off the marketplace with a Ryzen 5 something-or-other, and it beats my 2700X single-core and gives it a run for its money multi-core. And it's a mid-range part - in a laptop!
  14. sandys
    sandys Multimodder
    26 Mar 2006
    If you have carplay then it is likely you can use some of these things despite year
  15. sandys
    sandys Multimodder
    26 Mar 2006
    I had loads of similar problems with my DDR4, I have been using the same sticks since Zen 1, Zen 1 and Zen 2 topped out for me at 3400 too for 4x8 sticks, but on my 5950x 3800 was no bother, mem controller loads better, I could even run my 3600C16 @ 4000 but I had to down clock F clk or something so 3800 was the performance sweet spot.
  16. sandys
    sandys Multimodder
    26 Mar 2006
    So a 9900x puts out ~3400 single core and nudges 20k multicore, it is indeed a beast, my old tweaked out 5950 is slow at 15.6k :( In the Processor Benchmarks - Geekbench an average 5950 is listed as 12k multicore so mine is doing well, don't seem to have 9 series results in the chart for some reason?
  17. Byron C
    12 Apr 2002
    Nope:
    No bueno because no CarPlay, wired, wireless, or otherwise :thumb:. The only USB socket is there for power (which is so weak it won’t even charge my phone) and iPod only - believe me, I’ve tried :grin:
  18. Andersen
    25 Nov 2002
    Half-wifey's birthday is coming up, thus a present :grin:
    Byron C likes this.
  19. Gareth Halfacree
    4 Dec 2007
    Spoke too soon!
    Was playing around with processing the scans, and hitting some really weird errors. First, Tesseract output a zero-byte file, which pdftk then choked on. Never happened before. Then I found that ImageMagick had just... ignored one of the files in processing. Different file. It just... didn't process it. Then I tried processing all the files again, and it processed them all - but one of the files was corrupt, and trying to open it in The GIMP froze the whole desktop solid.
    So, reboot, DOCP profile reload, now running at 3,200MHz. Disappointing when I bought what I was told was 3,600MHz RAM, but I don't know whether to blame Crucial, AMD, or both.
  20. GeorgeStorm
    16 Dec 2008
    Is it an expo kit? If not I don't think it's guaranteed on an amd system to run at those specs, it shouldn't but not 100%
