  1. Mister_Tad
    27 Dec 2002
    Just from Barnes & Noble - $250/1.65-ish
    Not a great price, just an American one ;)
    I was in Vegas a few weeks ago and was going to pick one up then, but then heard about the announcement of a new Nook coming soon, so held off (which turned out to be a normal Nook)
    I'm in Chicago in another couple weeks, but have ordered in advance this time so it's waiting for me.
  2. Matticus
    Matticus ...
    23 Feb 2008
    Spotify Premium, I said I wouldn't, but couldn't resist.
  3. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Ordered a Dell U2711 screen on amazon, will be here on saturday. Fingers crossed it doesn't have any dead pixels or I'll have to send it back. :)
  4. MiT
    MiT Don't feed me after midnight!! nom
    18 May 2005
    bought some new rims for car (£450 19"BBC CH replicas) and one tyre Nankang N2 £80.
    also a zoom lens £250 for my 2 week trip to sri lanka in a few weeks.
    Going for my friends wedding, plus going white water rafting, caving,gem mine, jungle safari, and to a rain forest. Plus out and about. Cost $470 that's just the activities plus a few nights in different hotels. flights where about £500 then other accommodation about £117.
    then i need spending money. :(
    been an expensive few months!!
    oh and i had to share this:
    This is clay used for cleaning cars, after you have washed and dried your car, you can use this special clay, as you can see, this muck just come of the car after washing it (one small part of the car, not the whole car). Its normal tree sap and other stuff which builds up over your car, you are meant to do it every 6 months. The car then feels smooth as glass/mirror. :clap:
    spent about 2.5 hours cleaning the car the other day. (wash, dry, clay, hover, dash clean, window clean, foam clean)
    any way just wanted to share.
  5. kitt
    kitt Michael Knight
    8 Aug 2004
    Any linky's for that clay?
    You've got me curious now...
  6. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Beauty. Unfortunately you won't be able to go back to 1080p after this, trust me.
  7. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    It's recommended to wax your car after using a clay bar, though.
    And a bit of warning to those unfamiliar with clay:
    ALWAYS use lubricant! (Yes, yes... Dirty comments and all that... :duh:) Some bars are intended to use with a special lubricant, and some can use clean water (Bilt-Hamber have a nice one). That clay is incredibly sticky, and will be a mess if it sticks to the paint.
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
  9. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
  10. docodine
    docodine killed a guy once
    10 Feb 2007
    How do you like it so far? I had one for a short time, didn't really see the point of it.
    To be fair though, I had Cyanogenmod on it.. Honeycomb seemed to be too much for the CPU, but perhaps things have improved since mid-April. The Android dev community is quite amazing!
  11. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    A deposit for my next snowboarding holiday :D
    Stuff summer!
  12. MiT
    18 May 2005
    very true, the one i got comes with a spray bottle, you must use lub.:)
    I used a similar one from the same manufacture meguiars-quik-clay-kit.
    Heres the one i used(not bought from there just a link to the one):
    http://www.cleanyourcar.co.uk/detailing-clay/meguiars-quik-clay-kit-50g-clay-/prod_226.html
  13. Mister_Tad
    27 Dec 2002
    I wouldn't know yet. I'm not picking it up for a few weeks, it being in Chicago and me being in the UK ;)
    I don't really see the point of tablets in general (that's probably not fair, I see the point, I just don't think they're for me), hence picking up this instead of a much more expensive Flyer or Galaxy or whatever, for the sake of a play about.
  14. docodine
    10 Feb 2007
    I'll pick it up and load HC on it for you :p
  15. Smilodon
    25 Mar 2003
    Here is the one that uses water as lubricant: http://www.bilthamber.com/pro-intro...Wax :: Polish&name=Soft and Regular auto-clay
    They also sell the "regular" and "soft" individually.
    They also have something called Surfex HD. Which is a water soluble degreaser. It's excellent for engine cleaning. :)
  16. SouperAndy
    SouperAndy To Bumble or not to Bumble?
    16 Feb 2009
    Asus TF101 Transformer - Designated for couch potato use, XBMC on HTPC + XBMC Remote = :)
    16GB Micro-SD - for above
    Kindle 6" 3G - for the missus
    Bass Flute - again for the missus, $4,000!
    You can see who got the better deal!
    Cheers,
    SouperAndy :worried:
  17. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    And it's here. Love it. That is all.
  18. MiT
    18 May 2005
  19. Smilodon
    25 Mar 2003
    Yes I have. It's the stuff I'm currently using. I'm only using the soft clay, though.
    The surfex HD isn't the most powerful degreaser, but it works great on places where you want to rinse properly and avoid having a oily surface afterwards.
    MiT likes this.
  20. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    new set of 203mm DH bike rotors
    car biek rack
