  1. knuck
    knuck Hate your face
    25 Jan 2002
    I have the same mouse, the same pad, the same remote controller more or less the same Onkyo receiver :D
  2. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    This....
    - Arduino UNO R3 + 16x2 LCD + assorted jumpers, resistors, potentiometers, etc...
    The plan is to have the Arduino control fan speeds via PWM, control some RGB leds and also take data from the motherboard via serial interface (USB) and output temperatures, rpms, etc.
    The PWM part for the fans and leds is easy as the unit is perfectly capable of sending out PWM signal on its own; all it needs is to be given a duty cycle and off she goes. :D
    The RPM readouts part is giving some issues. I can read the tach wire on the fan and convert that to an RPM readout, but the fans I'm using (6K rpm beasties) are making the readouts jump at certain points. I have to figure out a way of cleaning the signal from teh tach wire so I get consistent readings.
    The temperature readouts straight from the motherboard are going to be another issue... I know I could get all this done with LCD Smartie and that it would take me minutes, but where is the fun in that?
  3. immoral
    immoral What's a Dremel?
    21 Mar 2010
    You are a man of good taste.
  4. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Silverstone FT03B
    EVGA P55 Micro SLI
    Corsair H80
    8Gb Corsair Vengence
    ASUS RoG Vulcan ANC headset
    Win :)
  5. Orca
    Orca What's a Dremel?
    2 Dec 2005
    Got a Drift HD Action Camera (the new smaller one) and a 32GB microSD card on the way :rock:
  6. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    a second gtx 570 and a Gigabyte GA-Z68XP-UD3P so I can run sli.
    just need to save for a full cover block now
  7. Auxilliary
    Auxilliary Crashes into space stations
    27 Jan 2011
    For the i7 I just bought off of the market place :)
  8. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    There was a 3 day deal that logitech had on, if you had bought from the site before. I'm kinda kicking myself for not ordering more TBH. I'm really lucky it came up at a time when I was looking for a new headset, it should really kick the 4 quid set I've been using into the ground.
  9. samkiller42
    25 Apr 2006
    Ordered my 4th and last 1TB Samsung F3, And i'm on a knife edge on ordering a Controller card from Scan.
    Sam
  10. Matticus
    Matticus ...
    23 Feb 2008
    I just bought a box... So I can ship my dead F3 back for RMA.
    Seems a waste of money but a heck of a lot cheaper than buying a new HDD if they void the RMA/Warranty due to shoddy packing. Also I will get a box back when they send a new HDD, so... that's good I guess :hehe:
    I am genuinely interested to see how they will ship me a box, I hope it's in another box just slightly bigger.
  11. longweight
    7 May 2011
    Flat packed :)
  12. Matticus
    Matticus ...
    23 Feb 2008
    I would have thought that normally, but it includes all the foam inserts which fit snugly inside the box.
    Either way I will just be glad to get my HDD back. I am going to buy another HDD at the start of next month as well for backups internally. One can never have too much storage/backup, Says the man who recently sold a HP Microserver with 2x 1.5tb drives because I wasn't using it...doh!
  13. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Just been staring at my current electrical socket situation in my bedroom; I have 13 appliances, and only 4 sockets ( 2x 2 gang outlets ). Having to run numerous socket doublers & extensions is a mess, so I bought a 2 gang > 4 gang socket adaptor ( swap faceplates and you get 4 individually switched sockets instead of just 2 ), and a surface mounted 2 gang outlet which I plan to run from another socket so that I have it where I need it. Also ordered 3 metres of cable trunking so that I don't have 3 or 4 cables & leads running along the carpet on one wall in plain sight.
    Fun little project that will tidy things up quite nicely. :)
  14. stonedsurd
    11 Mar 2009
  15. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    Howdy partner!
  16. stonedsurd
    11 Mar 2009
    oh hush, you.
    They're very sharp.
  17. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Bit late but I had this delivered on friday :) 680 :) :)
  18. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    My good man, what a nice GPU but do try to clean your radiator. It looks like it's full of dust!
  19. KidMod-Southpaw
    28 Sep 2010
    Flash photos reveal all. :worried:
  20. Guest-23315
    Guest-23315 Guest
    Also helps if you plug the power in :lol:
