Other Latest uTorrent Silently Installs a BitCoin Miner
Discussion in 'General' started by lancer778544, 6 Mar 2015.
  1. lancer778544
    lancer778544 isnt really an ultramodder...
    5 Jan 2011
    More here and here.
    If you've just updated uTorrent then check your task manager for EpicScale.exe. If it's running, stop the process and head to C:\Program DATA and delete the EpicScale folder. Might be worth running your favourite malware removal tool at this point too.
  2. Instagib
    Instagib Well-Known Member
    12 Mar 2010
    Sneaky buggers. Its not the first time such a thing has happened though.
    I'm using torrents less and less these days with services like
    Pornhub,
    Netflix and Spotify, so I suppose this is as good a reason as any to finally remove uTorrent and stop downloading stuff.
  3. Shirty
    Shirty Time travelling rogue Super Moderator
    18 Apr 1982
    Deluge. That is all.
  4. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    Brilliant!
    Thanks!
  5. lp rob1
    lp rob1 New Member
    14 Jun 2010
    This. I never trust proprietary software, as this is the stuff they can do without anyone noticing (until they get greedy, at least).
  6. pilsner72
    pilsner72 Member
    2 May 2011
    I reinstalled it late last night on my laptop and Kaspersky popped up with a warning.
  7. Kronos
    Kronos Well-Known Member
    6 Nov 2009
    I read about this also but was unaware or the removal procedure. Thanks.
  8. elise_s1
    elise_s1 New Member
    26 Jan 2015
    has anybody experience with Transmission in Windows?
  9. TheJackal
    TheJackal Getting Old
    3 May 2009
    Transmission is great been useing it over a year now
  10. Kronos
    6 Nov 2009
    Oddly I do not have any sign of Episcale on either PC and both are relative fresh installs.
  11. Atomic
    Atomic Gerwaff
    6 May 2002
    Glad I dumped uTorrent and moved to Deluge now, the ads stopped me using it as they were bordering on NSFW but now this just takes the piss.
  12. InSanCen
    InSanCen Buckling Spring Fetishist
    30 Mar 2005
    It's an "option". You can just uncheck it on installation. No different to many other pieces of software that offer other installations.
    That said, Deluge is my go to when I want a new ISO. It just works.
  13. panda_uk
    panda_uk New Member
    30 Jan 2015
    Thanks for the deluge tip. I can't believe those cheeky *****, last time I use utorrent.
  14. Kronos
    6 Nov 2009
    I switched to Deluge but I found set up not quite simple as Utorrent. No matter which pot I give it I still get the yellow triangle. Seems to work OK though even so.
  15. Kronos
    6 Nov 2009
  16. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    Nothing is ever free these days glad i have a good antivirus kaspersky...
  17. EvilMerc
    EvilMerc Well-Known Member
    1 Feb 2010
    As far as I can ascertain this doesn't affect OSX machines. I don't think EpicScale even has an OSX version in the first place, so this was a completely unnecessary mild panic for me.
  18. freshsandwiches
    freshsandwiches Can I do science to it?
    9 Aug 2009
    Couldn't find any evidence of it. Running 3.4.2
    However I have disabled all the ads etc.
