Development lazy char removal
Discussion in 'Software' started by Jaz, 4 Dec 2002.
  1. Jaz
    Jaz Banned
    18 Dec 2001
    I download lots of files and extract files from rars and zips, some of these files contain _'s (underscores) and would like an easier way to remove them rather than editing them myself i.e. using a button. Is this possible to script and make my own commandbar (taskbar) or are there scripts out there.
    i have tried creating a bat in the sendto folder with the code:
    @echo off
    cd /d "%1"
    for %%a in (_*.*) do set fn=%%a&call ren "%%a" "%%fn:~1%%"
    but no work
  2. x24
    x24 What's a Dremel?
    9 May 2002
    I can do it in VB :D
  3. NuTech
    NuTech Minimodder
    18 Mar 2002
    Just use Renamer, its free and allows multiple files to be renamed at once.
    It also has a one click feature to either remove underscores or replace them with a space.
    Been using it for ages now and I regard it as one of those tools that I cannot live without.
    Hope that helps.
