I have just recived my LCD 5" (voyager 5). This connection have to be changes so it fits the power from my PSU molex connector... How??
Open up the connector and there should be two wires. The one leading to the middle pin thing on the connector you connect to the 12v (yellow) wire and the wire connected to the outer part of the connector you connect to the ground (black) wire.
Like this?? Picture with molex and open car connector Picture with molex and open car connector, and me drawing the connection
yep both the black cables do exactly the same job and are prob soldered onto the same point on the psu, so any will do
Update on my LCD mod In this folder there also some movies of the LCD playing a movie.. Pictures are perfect.. but text size are to small to be shown... Is it possible to have a smaller resolution the 800*600 ??
This is a TV LCD ... (tv inn - yellow cable) Are there anyprograms that can let me use the LCD f example when I playing Battlefield...?? Know I have to hide The fullscreen game battlefield, to write in the MSN messenger window om my 2nd screen (LCD) Is there a away to still be in the game and write in messenger at the same time.. a shortcut would suite be fine... Press ALT when typing in MSN messenger... else the commands goes to the game...
