Modding [LCD] Blinkenlights movie player for HD44780
Discussion in 'Modding' started by yarvieh, 2 Feb 2003.
  1. yarvieh
    yarvieh What's a Dremel?
    28 Sep 2002
    While writing features for LcdStudio 1.5 somebody send me some blinkenlights movies. These movies are actually quite funny to watch and since i didn't want people to wait for lcdstudio for seeing this i created a stand alone player with the HD47780 driver. You will need dlportio installed and a 4 line display..
    click for (xvid) avi
    I included one movie, but if you want more there are tons at blinkenlights.de
    link to Installer
  2. kiwi-x
    kiwi-x What's a Dremel?
    16 Jan 2003
    i don't know what just happened in that vid... it's a little had to follow (i think, in part of it, a guy jumped off a building)
  3. dakar
    dakar What's a Dremel?
    6 Mar 2002
    Hmmm..something awry here... the installer runs fine, however when the app is launched i get the following..
    blinkje: Runitime error '429'; AxtiveX component can't create object.
    dlportio is installed and no other app is accessing the parallel or serial ports... (i have a HD44780 vfd on each)OS is XP Pro.... is there something i'm overlooking?
  4. yarvieh
    28 Sep 2002
    on some systems the hd4480.dll doesn't seem to be registering, can you try a manual regsvr32 hd44780.dll and see what happens?
  5. Jack
    Jack Minimodder
    22 Dec 2002
    I know!!! then there was some sexual sperm thing going on lol
  6. dakar
    6 Mar 2002
    That did the trick... thanks. pretty cool little app :D
  7. dez
    dez What's a Dremel?
    16 Jul 2002
    lmao. those guys are crazy, i remember ages ago i used to connet to their **** over telnet from school and watch it on the computers when i was boerd.
    blinkenlights.towel.nl
    ::edit #2, i tryed it to be sure, i had it wrong, its ' towel.blinkenlights.nl ' ::
    try connecting to that through telnet. im pretty sure that was the address for the entire first star wars movie. funny stuff, some ppl have too much time on their hands.
    dez
    ::edit:: after visiting their site, im not to sure if it is the same guys, no matter
  8. FLECOM
    FLECOM What's a Dremel?
    3 Feb 2003
    definately hillarious...
    now to make the noritake version :D
  9. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    How do you do that?
  10. dakar
    6 Mar 2002
    open a command window...
    cd \program files\blinkenlights lcd (ow whatever dir you isntalled to)
    then type in the command regsvr32 hd44780.dll and it registers the .dll.
  11. yarvieh
    28 Sep 2002
    i've updated the installer it should be fine now, but then again.. it should have been fine from the start... :sigh:
