Electronics LCD brightness
Discussion in 'Modding' started by nosmo, 30 Jun 2004.
  1. nosmo
    nosmo What's a Dremel?
    5 Oct 2003
    My LCD needs -14V
    I have connected it to the -12V supply and even with the contrast pot turn fully up I can only just see that the display is on.
    Bearing in mind that I have only connected the power so far so I don't know what I should expect to see.
    Is this because the voltage isn't correct or becasue I won't see anything until I connect the parallel cable up and get some s/w running ?
  2. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    With just power you should just see a row of dark squares, (or light squares if it is inverted) you may need the full -14v to bias it, so check out some dc-dc converters and see if you can find a cheap one.
  3. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    One easy trick is to take two 9V batteries and wire them with the positive side to ground, and negative side toward your -17V supply (your pot) and then use the middle wiper of the pot to get your contrast voltage.
  4. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    You haven't said what type of LCD you have. With graphic types, you won't see anything no matter where the contrast pot is set to.
    With alphanumeric types you will see alternate rows of solid squares.
  5. nosmo
    5 Oct 2003
    Sorry it is a graphic so I guess I'll have to get the iron out and wire up the parallel cable before I even know if its working.
