Modding LCD "build-in"?
Discussion in 'Modding' started by Mr-IK, 2 Jun 2007.
  1. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Hi you guys.
    I was wondering, if it would be a bad idea to build a LCD screen straight into the side of a midi-tower?
    Thank you :)
  2. fungry
    fungry What's a Dremel?
    14 May 2006
    well like any thing else, if its a job well done, then i'll say its worth it.
    though what about the circuitry/wiring and stuff?
  3. saltynay
    saltynay What's a Dremel?
    12 May 2007
    yes its been done a few times before if you want to make it extra cool go with a touch screen :D
  4. fungry
    14 May 2006
    ooo touch screen would be good. and if you have vista, maybe you could somehow put that screen as your sideshow screen :D:D.
  5. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Use Linux and put the money you save to more mods.
    Sounds like a good idea.
  6. elctroJunky
    elctroJunky What's a Dremel?
    9 Jan 2006
    I've mounted a 15" TFT I got from eBay (for 7€) on the side of my old computer.
    It was so cheap because the inverter was broken (replaced it with one of those CCFL inverters).
    Since I bought that screen for just 7€ I got an idea.
    Why not get at least 4 screens of the same size and build a cube case... with TFT's as walls!
    I haven't started with that, so if you want to build a TFT into a case and still want to do something new, you might want to build this TFT cube yourself ;)
  7. fungry
    14 May 2006
    haha true that! hmmm
  8. saltynay
    12 May 2007
    make it 5 screens and make the top a touchscreen lol the ultimate cube case
  9. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    lol!!!! that would be awesome!
  10. Bas van der Werff
    Bas van der Werff What's a Dremel?
    18 Feb 2007
    And to really make it special put a small webcam on the inside on all 4 sides so you can still look inside:D
  11. x06jsp
    2 Apr 2007
    lol!!!
  12. saltynay
    12 May 2007
    no what you need to do is the james bond trick with the invisible car you mount the camera on the opposite panel to the screen so that it shows the picture as if it wasn't there.... the left panel would show the picture from the right webcam and the right panel would show the picture from the left webcam as if there was no case there.......
  13. x06jsp
    2 Apr 2007
    hahaha those are both awesome ideas!
  14. saltynay
    12 May 2007
    just wondering how would you connect these monitors up???? what sort of internal monitor connection would you be able to use...... or would it just be a case off filling the pci slots with lots of low grade graphics cards
  15. elctroJunky
    9 Jan 2006
    Depends on what you want to show on the 4(5) screens.
    If you want a nximum of 2 different pictures, you can use one video card and split the cables so that the two pictures (modern video cards can connect two VGA screens) are shown on the 4 monitors.
    If you want a different picture for every screen you need at least two video cards with dual screen support (if u have 4 monitors, else 3 cards to get all 5 working).
    I don't know if windows can handle multiple video cards, but Linux can!!
  16. fungry
    14 May 2006
    hahaha dude that would be a serious mod!
    i really like the idea !
  17. saltynay
    12 May 2007
    I am tempted to give it a try but don't have any money..... anyone to donate to it I need £600 to get it up and running with water cooling :)
  18. x06jsp
    2 Apr 2007
    lol ummmmm no
  19. saltynay
    12 May 2007
    come on if 60 people give a tenner then it will become a reality :) if 60 people donate £20 then I make it touch screen and put better then the lowest of the low components
  20. x06jsp
    2 Apr 2007
    lol!! just walk around the streets of wherever you live with an 'nspcc' rattle bucket thing for a few weeks and your sorted!!! lol
