Modding LCD "build-in"?
Discussion in 'Modding' started by Mr-IK, 2 Jun 2007.
  1. saltynay
    saltynay What's a Dremel?
    12 May 2007
    no that won't work ppl don't give enough money you would only make about £70 a day
  2. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    yer 70x 15 (if you go ouyt for 3 weeks)= 735!!!
  3. saltynay
    12 May 2007
    3 weeks everyday I don't have that much free time in the summer first I have: egypt for 3 weeks, then Duke of edinburgh for a week, then going to malaysia/indonesia for 5weeks then a week at home and then back to school I can't fit begging into my busy schedule!!!
  4. x06jsp
    2 Apr 2007
    lol ummmm ok i dunno then!
  5. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Oh i forgot to tell you what i actually meant ;D
    I meant "will my hardware be safe with a screen that close by?"
    I dont know if the "magnetic/electric field" there seems to be on CFT's are in TFT's aswell?
  6. saltynay
    12 May 2007
    nope EM doesn't affect tft's or so I am guessing as I have a lamp on my desk whenever I turn it on I get a wash of colour over my crt but my tft's are fine
  7. Colossous
    Colossous Minimodder
    28 May 2007
    Will it add much heat to the case though ? :duh:
  8. elctroJunky
    elctroJunky What's a Dremel?
    9 Jan 2006
    Well, TFT's don't create much EM interference. They don't work with EM fields to get a picture on the screen, so they are pretty much safe in both directions (creating EM and being influenced by EM).
    Well, with one TFT heat won't be an issue. The electronics don't create much heat, the only thing that heats up are the backlights (CCFLs, but if you're good enough you can convert it to LED backlight, that'll reduce heat production and power consumption... I've already seen someone doing that).
    So you'll have about the heat production of another hard drive or two. A good air circulation will do fine (despite the fact, that TFT's don't come with fans included, so that should make a statement for itself, shouldn't it?).
    As for the Screen Cube (or let's call it OMNI-SCREEN) I'm going to do that if you won't(after all it was my idea in the first place)...
    But I'll take my time for that... getting 4-5 TFT's the right size and the right price will take some time(I'm watching eBay carefully, trying to find the screens with a damaged backlight, that's easy to fix and they're quiet cheap). Finding the right graphics cards will be the hard part.
  9. Tzi
    Tzi Unartistic Imaginator
    11 Jul 2007
    Maybe a matrox or two, they used to work great for that sort of thing. Does anyone have a link to where someone put an LCD into the side of the tower, I'm looking to do this now, but no amount of searching has turned up good results.
  10. Metatron197
    Metatron197 What's a Dremel?
    8 Oct 2006
    Make it so that the screens fold out away from the case so that you can see all of them at once.
  11. Skulldragger
    Skulldragger What's a Dremel?
    28 Jun 2007
    Just FYI windows has since Win98 SE, though Linux can do it better >.>
