Modding LCD Communication via DOS / Cmd Prompt
Discussion in 'Modding' started by Cruelinios, 27 Sep 2002.
  1. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
    Does anyone know the code to send text to an LCD via the dos prompt or cmd in Windows 2k?
    I was wondering if you could then fill one character block on the LCD with black. From this I want to achieve an animation that I will run when the computer is started.
    The animation I hope to achieve will be like a bar graph / graphic equaliser form.
    Thanks.
  2. x24
    x24 What's a Dremel?
    9 May 2002
    It's possible if the LCD is on the serial port since I know that there is a command to send data to the serial port in a command line.
  3. philth
    philth What's a Dremel?
    25 Jul 2002
    If your display has on board macro programming you could write a macro into position 0 which will display on power on, saving you the hastle of writing a dos program.
    philth
  4. Cruelinios
    21 Jan 2002
    the LCD im using is a HD44870 Parallel 4x20 LCD with backlight.
    Not sure about macro programming, I will have to check...
