Modding LCD cube case mod
Discussion in 'Modding' started by SingaBoiy, 3 Feb 2005.
  1. SingaBoiy
    SingaBoiy What's a Dremel?
    3 Feb 2005
    Nice forum btw. Im just starting out in my modding.
    I am going to build a cube case with an 10.4" LCD touchscreen in the front of the case. I have done some soldering in my day, nothing special though. The one I was looking at was a FDP LDH102T-33. The specs on it arent so good but im gonna be getting it for $50 (screen only). I wanted to know if there was any info I could get on getting the monitor to work like that w/o the back part. Here are some images of what im getting:
    http://bob-erecycler.zftp.com/LDH102T-33-1.jpg
    http://bob-erecycler.zftp.com/LDH102T-33-2.jpg
    Im about to use AutoCAD to design it. The case will be made of plexiglass. Maybe 11-12" each direction. Just want to see if there is any other info I can get.
    TIA :D
  2. Gabe
    Gabe What's a Dremel?
    19 Jan 2005
    sounds sweet, cant wait to see pics when your done. good luck on it
  3. rankie
    rankie What's a Dremel?
    12 May 2004
    I'm afraid you cant do anything usefull with it without a controllerboard and they're normaly $100+
  4. SingaBoiy
    3 Feb 2005
    Controllerboard? Damn. What about with just a normal LCD screen?
    EDIT: Here is what I was planning. Very rough sketch :naughty:
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    Welcome to the forum!
  6. SingaBoiy
    3 Feb 2005
    lol... that wasnt with CAD. My disc isnt working properly :wallbash:
  7. FuzzyOne
    FuzzyOne
    19 Sep 2002
    no **** :D
  8. SingaBoiy
    3 Feb 2005
    Anyone have an ideas to improve the layout and airflow. Just need to make it look good :)
    And any other info on LCDs in the case.
  9. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    Have the side fans as intake and the top as exhaust. Remember, heat rises.
  10. SingaBoiy
    3 Feb 2005
    Ah yes. I was thinking id have it on the bottom so it could pull the heat away from the cpu easily.
  11. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    looks sweet dude
    Good luck
    -S
