OKEY, first sori on my bad language... I have a Pioneer DVD player DV-444 , and its broken, but it has good display... so im asking help if someone can provide me some guide how can i use it on my comp as some maxorbital and other displays? thx in advance im ready to mod
not going to happen unless you can build your own controller. those lcds are usually custom-built for the dvd player.
yes, i can build that... buth i need some sheme to build it... my friend goes to electronic shcool and there he can build everything whith some prof. assist... so, im asking if its posible to do that and how can i do it..what thing do i need
Yes you need the datasheet, then you can determine which LCD controller is suitable and find the application note to build the circuit. Then the question arises whether any existing LCD app can support it, otherwise you'd have to write your own software too. If it's one of those small DVD status displays then don't bother, for a couple of euro's you can buy a (bigger too) ready to solder character LCD, which is supported by almost every LCD app. On the other hand yes it's much more fun getting stuff like that to work
