News LCD/FAN Module :: MeetTheGeeks.org
Discussion in 'Article Discussion' started by Cheese, 16 Sep 2002.
  1. Cheese
    Cheese Doc
    6 Oct 2001
    {param}
    "On the whole the biggest problem is some people wont be able to fit them without instructions. Its not hard but some people not technically minded maybe wont be able to do it. There's no details on there website either to help you. Its nice to be able to monitor heat in certain areas of your case but if you buy this unit and THEN have to look for probes of some type and then plugs to make them fit you start to lose faith in it all. If its a kit of parts, you need all the parts or at least an option to get some. I do like these products and integrated as one unit. The ability to monitor CPU and other temps and have fan control is perfect, together it works, separately for some it works, combined as one easy to fit unit, its a blinding solution to a lot of clockers and modders problems. Maybe time FeelingPC relooked at it all and tried it our way ?"
    Review here.
Tags: Add Tags
