Modding LCD help with shuttle is their a parallel?
Discussion in 'Modding' started by MiNiMaL_FuSS, 8 Mar 2005.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    I've just got hold of a small LCD for the front of my shuttle SN41G2.
    Unfortunately it's wired for parallel port, and the shuttle dosnt seem to have one.
    However i have seen somewhere that the port is optional when you get a new shuttle....does this mean its there internally somewhere? and i cna wire my lcd to it?
    if not is there some kind of simple way to convert it to serial port or something?
    Thanks!
  2. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    The parallel port header is on the motherboard to the right hand side of the ICE block, right behind the serial plug on the back (on a 45G). As I think it's a parallel jobbie, you'll need to buy the shuttle parallel kit to hook it up unless you're lucky enough to find a plug and wiring diagram somewhere :)
