Modding lcd mod, help needed, please
Discussion in 'Modding' started by gar, 4 Apr 2007.
  1. gar
    gar Minimodder
    15 Sep 2004
    Hi guys!
    I'd really appreciate the help if possible.
    My monitor is one of those ones with the reflective screens, so when I am using, it reflects everything insight, so I can't see what I'm trying to look at . Is there anyway I can change my monitor to a matt finish so I won't have this problem?
    thanks in advance,
    Gareth
  2. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Your best option would undoubtedly be an 'anti-glare' screen filter, which you just attach to your monitor.
    This is one example, but of course they come in all sizes - and different qualities.
    They can get quite expensive for the better ones though!
  3. gar
    gar Minimodder
    15 Sep 2004
    Yeah, that would definately solve my problem. We had one on our old crt, but I didn't like the look of it tbh. If there was some way I could go about modding the screen with some sort of film or plastic if pos I'd go for that. I do appreciate the sound advice though!
